• 05.01.2026, 06:26
Top_Nurse
Tubemeter issues and mods
Freitag, 25. November 2005, 10:15
Greetings most exalted ones...
Need some information in regards to my Tubemeter. I have been looking at the Tubemeter manual and I am wondering if NC = No Connection on Pin 1 below:
If this is correct then I assume I can use a 4 conductor cable to do some custom wiring solutions?
The pins coming off the bottom of the Tubemeter are problematic for me because they take up too much space when the connector is on it. So I have already started to mod my Tubemeter as seen below by removing the pins.
Mr_modnaR
Re: Tubemeter issues and mods
Freitag, 25. November 2005, 10:25
I think that's correct, as it's a usb connection. :D
Hope this helps
x-stars
Freitag, 25. November 2005, 16:00
Yes, menas not connected (or, when I rember reight, it's connected to Ground on my tubemeter :)).
Top_Nurse
Samstag, 26. November 2005, 00:07
Thanks for the reply. You can see what I have been doing in FF with my Tubemeter mods now. ;D
Top_Nurse
Sonntag, 27. November 2005, 08:29
Will a Tubemeter work in the non-conductive liquids becoming more popular here in the USA?
Mr_modnaR
Sonntag, 27. November 2005, 12:24
not sure how it actually works (the tubemeter) but i'm assuming it works by connecting pairs of contacts through the conductivity of the water. so i would say no, or very intermittently.
hope this helps
Top_Nurse
Montag, 28. November 2005, 00:12
Yeah that is the issue and how much conductivity do you need to get it to work properly. Some people in the USA are asking about this due to use of non-conductive coolants. Anyone using any of these solutions with a Tubemeter?
x-stars
Dienstag, 29. November 2005, 11:45
What coolants are you talking about (KM :-/)?
Mr_modnaR
Dienstag, 29. November 2005, 16:14
Back in her watercooling days, my old gran used to say:
"if conductivity is a problem, just use mercury"
;D
MUFFDIVER
Dienstag, 29. November 2005, 19:57
lol and i have a friend using non conductive witht he tubemeter but aint answering on msn >:( but hey i cant force him to talk to me. but when i know il let you peeps know. ;D
