Sie sind nicht angemeldet.
! Great! So I guess with the plexi top, there are holes on the upper and lower sides of the inlet/outlet ports? So for the inlet port, you can just cap off, say, the top hole and use the bottom. And then for the outlet, I could cap off the bottom and use the top? Or something like that?-
