• 13.03.2026, 06:54
blexley
Why does aqua-computer use a Eheim based pumps ?
Dienstag, 18. März 2008, 11:39
Out of intrest why do you guys use a Eheim based pump and not the DDC or D5 vario ?
Thanks
Stefan_K.
Re: Why does aqua-computer use a Eheim based pumps
Dienstag, 18. März 2008, 13:13
We like pumps that are reliable over many years. ;)
blexley
Dienstag, 18. März 2008, 14:28
Thanks for the reply Stefan
I'm tempted to buy one of your pumps
Apart from them being more reliable are they any louder or quieter than the laing pumps and would i have any problems running the Aquastream on a large 1/2" pipe system ?
thanks
Stefan_K.
Dienstag, 18. März 2008, 15:47
no problem on big tubing. The XT s are quite powerful and they are really quiet compared to other pumps.
blexley
Dienstag, 18. März 2008, 15:53
Thanks Stefan
One last question
Do the pumps make a whistle or whine noise at all like a hard drive spinning as that would drive me nutz.
pharao
Dienstag, 18. März 2008, 16:25
they don't. :)
Cobra88
Dienstag, 18. März 2008, 18:20
Hi Guys
I have an Eheim 1052 Aquarium pump i bought in approximately 1987 possibly 88 and it's still running perfectly on my s a l t water Reef tank. (had to space word :-/)
only replace impeller spindle once in that time
because it broke when i was cleaning it (i dropped it & it's ceramic) there was no visible wear on the spindle at all.
this pump was run continuously apart from about a month when i moved house.
Regards
Rick ;)
blexley
Mittwoch, 19. März 2008, 09:34
Thanks
