Sie sind nicht angemeldet.
Zitat von »smooth«
My case is a powermac g5 case so space is limited. I want two loops, and was wondering if i could make the loops "share" an aquatube?
Also what happens if you sleep a watercooled pc? Do the fans and pump stop or do they run and defeat the object of sleep modes?
usually the fans stop (since they are powered by your PSU. If you use a 12V pump it will stop working, too.No, you can switch it off for several weeks, no harm
Do water cooled pc's have to be used regularly? Or does the water have to by cycled?
What maintence has to be carried out?
