• 13.07.2026, 20:46
Kenta777
Bought Ampinel - did not fit. Help a noob out.
Montag, 11. Mai 2026, 18:31
Hi!
Hope english is OK! :)
A bought an Ampinel in februari and I got it today! Yes!!
It does not fit, 100% my own fault.
You see, I got the right version but I figured out I have a CPU cooler in the way. Did not think about that when ordering.
So what to do? No I won't install a waterblock. :)
Never mind the dust. :)
Hilfe!
Earthrise
RE: Bought Ampinel - did not fit. Help a noob out.
Dienstag, 12. Mai 2026, 16:38
Well, you could install a waterblock! :D Seriously, your best bet would be to switch your CPU cooler for an AIO.
Hilfe!
lol :thumbsup:
Kenta777
Mittwoch, 13. Mai 2026, 17:44
AIO
Well ... I'd guess someone would answer that. :)
Is there someone special to recommend?
I have a Ryzen 7 9800C3D CPU on a AM5 motherboard.
I had a AIO many years ago. Quite high sound (clicked-pump sound) and I have a computer for quite long time so it needs to be very reliable.
Danke!
GriDeVl
Mittwoch, 1. Juli 2026, 17:43
In order to install Ampinel, consider replacing the cooler with an AIO. There are many All-in-one cooling solutions for every taste and budget. Just look at the reviews and tests before buying.
I7-12700K/G-Skill 64GB(6000)/Asus Hero Z690/Asus TUF 3080LHR/Corsair HX1000/Creative sound blaster x3/Phanteks M25-120x10/Lian Li Dynamic evo/EK Quantum Velosity2/EK Quantum Vector TUF 3080/3090+Active Backplate/Watercool Mora 9x140 Pro/Heatkiller D5 150/AC D5 Next x2/AC HF Next/AC Hubby7/AC Aquero 6LT/Arctic P14 Pro x18/Schlauch Watercool 10x16/Koolance GD3/Fitting Bitspower, Barrow
Freitag, 3. Juli 2026, 00:48
Noctua just released an AIO. May be worth looking into. der8auer did a review video.
https://www.youtube.com/watch?v=27l8MqNvBRQ
GriDeVl
Freitag, 3. Juli 2026, 22:47
On Noctua, the light did not converge in a wedge :) There are still AIO manufacturers who produce good products. It all depends on the preferences and finances that can be spent. I looked at your hardware and, if finances allow, I would get off the air and assemble the contour at least on the hoses. Please write the name of your building, as the selection of AIO options also depends on it.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »GriDeVl« (3. Juli 2026, 23:09)
