• 02.10.2026, 04:44
Andso
Project NJOY Twin Lian Li
Donnerstag, 25. September 2003, 20:15
Well hello sorry for not writing in german that's because I am from the Netherlands.
I'am working on my new project NJOY twin Lian Li I use 2 lian li PC60 cases one is for the hardware and one is for te wc setup.
When I started the project I did have a compleet AMD setup but that is now a P4 the project is not completed that is becuase some other things and small projects and I did have a lot off problems the get the components
The WC that I did want to use was Cooltech I did try to get that direct out Italy but the only thing I did het was the radiator. So I must what else :) So I did try to get Swifttech WC so I did order them but I still wait on them that is know for almost 3months. Then I did discover that H. Essers Aqua Computer inports in Netherlands and I was in love :P So I did order that I only have to get 2 components but that will be good.
Everything is hand made so It takes a lot off time to complete the project
Components (sorry for some dutch words in it)
Case:
- 2x Lian Li PC-60 kasten
- 1x Lian Li Side Panel PC-65s
Voeding:
- Enermax 460 Watt (FMA EG465P-VE FCA)
- Enermax 365 Watt (FMA EG365P-VE FCA)
Case Fans:
- 3x Enermax 120 mm fan adjustable (Bleu)
- 1x Enermax 80 mm fan adjustable (Bleu)
Cooling (Water Cooling):
- Aqua Computer CPU cooler cuplex evo Plexiglas Revision 1.1
- twinplex™ für ATI-Grafikkarten (z.B. 9500,9700,9900 GPU cooler
- Cooltech radiator 2x120mm fans
- Pomp Eheim 1046
- Reservoir Aqua Computer aquatube Rev. 1.1
- Engine Ice Coolant Complete
- Hardshell tube (Slang)
- Aqua Computer koppel stukken
Diversen extra's:
- 3x UV Rounded Cable- 1x Rounded Cable Floppy Zwart
- Alumunium RH-35 vier kanaals fan regelaar (zilver Bleu LED)
- 5x Cold cathode groen
- 4x Cold cathode blauw
- 6x Lazerleds groen
- Groene kabelbinder
- 1m spiral warp Zwart (Om voeding kabels heen wikkelen)
- Thumb screws
De hardware van de pc:
- Asus P4C800 Deluxe
- Intel Pentium 4 2.8Ghz 800Mhz
- Sapphire ATI radeon ?????? I waiting for the 9900Pro
- 512Mb Corsair DDR400 Twinx CAS2! Matched pair Low latency (Helaas verkeerd geleverd moest 1024Mb zijn)
- Promise Ultra 133 UDMA controller
- 4x Western Digital 80Gb 7200Rpm 8Mb Cache
OS Software:
- Windows XP professional Legaal!
Fron
Front no panel
Back
Inside
thumb screws of one PC60
Woot!
Andso
Re: Project NJOY Twin Lian Li
stripping :)
Zie losse onderdelen op achtergrond
Hier is het 5.25 gedeelte al eruit geboort
Nog een keer boren en dan is ie bijna helemaal kaal frame
De kappen van de kast
Alle Thumb screws nog niet allemaal uit 1 lian li kast
Lian Li problem?
Alleen op de originele kap van Lian Li met raam hebben ze dat niet gedaan
Dus heb ik dat ding er ook maar uitgeboord hoef toch geen slotje op me pc te hebben :)
Tada past :)
Nee ik heb me voeding nog niet binnen, maar ga ook niks met me voeding doen in feite hoef ik daar ook niks aan te doen heb een Enermax voeding besteld en die is al super standaard en kan m niet echt mooier maken.
Maar ben al wel een stuk opgeschoten met me 2de Lian Li kast die het nu dus een kleiner broertje gekregen :)
Eigen frame gemaakt aan de achterkant van het afval van de kast komt.
Met de bovenkap (nog niet af komen nog gaten in)
Extra gaten gemaakt voor de voorkant te kunnen bevestigen
Ingekorte voorkant
Exact hetzelfe als het origineel bevestigd
De bevestigings schoeven voor de voorkant
Met de voorkant erop
Big brother and litle brother bij elkaar
Op elkaar
I have lot and lost of pics so I can post them I you want to see more
Woot!
kaZuo
Donnerstag, 25. September 2003, 20:32
uuh, what did you do to the pretty pc60 ;D
but this "small" pc60 looks very good so far
and YES I'd like to see more ;)
iNFiNiTE
Donnerstag, 25. September 2003, 20:35
hoi,
ik wil graag meer platjes zien !!! maar warom heb je nou noch een kleine lian li er opgezet ?!? wat heb je dar aan ?
edit: sorry, ik heb overlezen dat je in de kleine lian li de wc wil setten , sorry :D
iNFiNiTE
Hotzenplotz
Donnerstag, 25. September 2003, 20:40
Zitat von »iNFiNiTE«
hoi,
iNFiNiTE
Dann is ja alles klar.  ;D
Zitat von »oldman«
Gehe Deine Lehrer verprügeln, die haben versagt.
Donnerstag, 25. September 2003, 20:49
LOL ;D
Looks really nice so far :) Show us more! 8)
Nacht-Elf
Donnerstag, 25. September 2003, 20:59
hey, i didn't know how good i understand netherlandish (wie nnen die holländer ihre sprache? :P )... is this small case on the big case the pc-65s? is this case big enough, to get a flex-atx motherboard into it? ;D
but very nice till now ;)
Pogo
Donnerstag, 25. September 2003, 21:58
:o wow the poor PC60 :) but nice work keep on modding we wanna see more pics
DSEDS
Donnerstag, 25. September 2003, 22:33
great, that you found your way to aqua computer. :)
We have some dutch users here.
Your project looks [glow=red,2,300]very cool[/glow].
Andso
Donnerstag, 25. September 2003, 22:40
Yes the Mini li goes on top :)
Fun that you can read the dutch comments I can read german (I did have it on school pfff that was a long time ago!) so it is no problem to reply in german/english or dutch
Some components
On of the 2 Enermax PSU
120mm enermax fans standaard al een fan controller op.
de radiator (Sorry no Aqua part :'( )
Opstelling radiator - bevestigings kap - 2x 120mm enermax fans (op foto maar 1!)
Some Simple Fan Bus that will be stripped!
Blauwe verlichting (niet echt goed zichtbaar in het licht)
Woot!
Andso
Donnerstag, 25. September 2003, 22:46
the first CCFL setup
Front green inside PC bleu
I didn't like the green on the front so
Asus DVD bezel
Origineel Lian Li bezel
Beschermlaagje zit ernog wel op maar je ziet bijna geen verschil
DVD speler zonder Lian Li bezel
Met de bezel
Woot!
Andso
Donnerstag, 25. September 2003, 22:52
The second PSU will feed all the 8 fans 9x CCFL 6x Lazerleds 1 LCD etc etc
I did make a pexiglas plate that is gegraveerd <-- {don't know any word for that in english or german)
When you light it whit lazerleds it will glow up
Ledjes zitten nog niet vast :(
Woot!
Nacht-Elf
re: Project NJOY Twin Lian Li
Donnerstag, 25. September 2003, 22:58
oh no, i can't read dutch (yes i've found the word ;D ), but if i read ... well more see it, i can imagine what you mean ;D
and keep on ;)
Andso
Donnerstag, 25. September 2003, 23:03
Woei! fun that you can read it! but pics say more than words!
2x 10cm CCFL in the front and 2x30cm CCFL bleu
I have a lot more pics to come!
Woot!
Andso
Donnerstag, 25. September 2003, 23:09
Yes I found the quote button!
But in the mini Li will fit a flex-atx (just like a shuttle)
Woot!
TrOuble
Donnerstag, 25. September 2003, 23:22
wow looks damn fine !
I really like "alien" Casemods from other countrys with AC comonents ...
ääh year ...
Welcome to the Aqua-Computer Forum !
MfG TrOuble !
freak34
Very Nice! Hope you are fast with the building of the watercooling and the Other Nice Things :)
ThaDog
Donnerstag, 25. September 2003, 23:39
Leute, ich machs mal auf Holländisch. das schreibe ich doch ein wenig besser als Deutsch, hehe
Wow, dat ziet er echt heel goed uit..... vooral de tweede pc 60, hehe, gewoon een koppie kleiner gemaakt.
Een heel goed idee !
Welkom in een van de beste Forums on the web, geloof me, ik als nederlander voel me hier helemaal thuis !
groetjes,
ThaDog
TrOuble
Donnerstag, 25. September 2003, 23:56
groetjes,
ThaDog
ich versuch mal zu übersetzen :
wow, das sieht echt sehr gut aus ... vorallem die zwei Pc60, hehe, gewoon (?) eine Kopie kleiner gemacht.
echt gute idee.
willkommen im dem besten Forum on the web, glaub mir, ich als niederländer fühl mich hier heimisch (?)
*g* ich hoff ma dat stimmt so einigermaßen ;)
MfG TrOuble
ThaDog
Freitag, 26. September 2003, 00:05
Sehr gut, TrOuble fast getroffen !
gewoon een koppie kleiner gemaakt = einfach ein kopf kleiner gemacht........ ist mal wörtlich übersetzt.......
Wir brauchen Domian !!! ;) ;D
mfg,
ThaDog
PS, Andso..... je hebt een IM ( KM ) !!!
