• 11.10.2026, 05:08
Jogibaer_Nr1
Re: casemod:AlumaxX
Monday, January 31st 2005, 12:31pm
looks very nice!! :) go on :D
landler
Re: casemod:AlumaxX
Monday, January 31st 2005, 1:39pm
@ franklin:
nice and a interesting mod :)
@ thadog
you mean this mod orac³ http://www.bit-tech.net/article/114/
hubsi
projekt nautilus rev. 3: eingestellt. die eos 30D bestimmt meine freizeit.
Quoted from "Nemesis"
andere essen chips beim fernsehen ich poliere ;D
Franklin
Re: casemod:AlumaxX
Tuesday, February 1st 2005, 8:44pm
Can you help me guys. I will buy the Ersatzdisplay LCD gruen invers SERIELL für aquabay CF, but I need the sizes of this thing. The more sizes the better. The most important sizes are the sizes from the hole for the LCD screen in the Frontblende für aquabay CF.
Franklin
Re: casemod:AlumaxX
Wednesday, February 9th 2005, 12:50am
Sorry no new pictures...................yet. I have made some paper models for the aluminium parts that will cover the motherboard, drivebays and the bottom section. I have almost finished the technical drawings so that the metalworker can bend the plates I need. To make everything fit in the case I will have to do a lot of dremeling and I look forward to sand and polish them  ;) What terrible job that is. I will have to do it all by hand. The harddisk rack already took about 6 hours to finish. I don't even want to think about the time it will take to do all these new parts.
A small preview of the acrylic front. It's only a paper model, I don't start cutting the plate before I have the aluminium sheet that goes behind it. (this aluminium sheet will replace the bezels)
The blue dots are the spots where the bolts wil be placed. I will have to modify the DVD bezels a bit because the acrylic glass is three mm. thick and comes in front of these bezels.
Franklin
Re: casemod:AlumaxX
Saturday, February 19th 2005, 4:03pm
The acrylic glass front is almost finished. It looks a bit different from the paper model. Behind this acrylic front there will come an aluminium plate with almost the same as the acrylic front.
The ejectbuttons will have to be cut out of the acrylic and the DVD drives will be stealthed with the same acrylic glass and aluminium.
I hope Aquacomputer will soon deliver my waterblocks and LCD screen. I just have received my new hardware. Two XFX 6800GT videocards, two plextor 716-S DVD rewriters and the ASUS A8N-SLI Deluxe motherboard.
ien-
Re: casemod:AlumaxX
Saturday, February 19th 2005, 6:43pm
the moddingparts done yet look awesome but wth do you need two rewriters :o
looking forward to your realization of a "clean" interior.
keep it up!
Corran
Re: casemod:AlumaxX
Sunday, February 20th 2005, 7:31pm
nice word - a little question - how did you melted the acrylic glas? and did you used speacial Acryl?
- The Force will be with you - www.koelneranimetreffen.de <- für alle Otakus
Quoted from "hot-bytes"
PS: AcidFluid is kein Energy drink für Modder ;)
Franklin
Re: casemod:AlumaxX
Sunday, February 20th 2005, 7:45pm
and a picture withe ejctbutton covers and the DVD covers.
I saw the acrylic glass by hand and then file it. To give it a smooth finish I use sanding paper. It's acrylic glass from ACRyan. It's very easy to work with, but it takes a lot of time to get it perfect.
-Xan-
Re: casemod:AlumaxX
Sunday, February 20th 2005, 7:52pm
freak .... ;D ;D ;D
Franklin
Re: casemod:AlumaxX
Sunday, February 20th 2005, 8:03pm
I hope I can start withe bay and motherboard stealthing next week. Waiting for the aluminium plates  :-/
I have made some paper models.
I can start finishing these models because I have the ASUS A8N-SLI deluxe motherboard and the two XFX6800GT videocards in now.
Everything fits just fine.
Now I just have to wait for my aquacomputer LCD and the cooling parts. Hurry up guys from Aquacomputer  ;)
the_king
Re: casemod:AlumaxX
Sunday, February 20th 2005, 10:39pm
very nice :o :o :o :) :) :)
:) Das Leben ist ein Scheiß Spiel, aber hat eine verdamt geile Graifk ^^
Black_Jesus
Re: casemod:AlumaxX
Monday, February 21st 2005, 4:41pm
very hot
the uv parts are nice
Franklin
Re: casemod:AlumaxX
Saturday, February 26th 2005, 2:35pm
The FMJ pump housings are back from the chromerguys.
imperator79
Re: casemod:AlumaxX
Saturday, February 26th 2005, 2:40pm
Why do you need 2 Plextor DVD burner ?! ::)
J_O_K_E_R
Re: casemod:AlumaxX
Saturday, February 26th 2005, 2:43pm
Oh wow, thats' nice..I think the pump houses are fitting perfectly into the whole case and the conception. What else did you send to the "chromer-guys" (that word sounds nice ;D)?!
greetings, Joker
Franklin
Re: casemod:AlumaxX
Sunday, February 27th 2005, 1:43pm
Quoted from "imperator79"
I burn a lot of Cd's and DVD's.
I didn't send anything else to the chromer..........yet. Maybe I will have a few other parts chromed as well, but I haven't decided yet.
Franklin
Re: casemod:AlumaxX
Wednesday, March 2nd 2005, 10:50pm
I had to wait a long time for the aluminium sheets, but now I can start modding again. I started with the aluminium front, the plate that comes behind the acrylic glass.
I drilled some holes for the Aquaero buttons and some holes that make it easier to remove some bits.
After some drilling it was easy to remove the part that has to make place for the reservoir.
After some filing and sanding the hole for the reservoir is finished. Now the rest.
Black_Jesus
Re: casemod:AlumaxX
Wednesday, March 2nd 2005, 11:20pm
wow very nice
fabelmann
Re: casemod:AlumaxX
Wednesday, March 2nd 2005, 11:21pm
I like the modified FMJ's
keep on pimping ;D
HoferSackal
Re: casemod:AlumaxX
Wednesday, March 2nd 2005, 11:24pm
you've too much money :)
btw: a really really nice mod. I like the green plexi very much. i'm looking forward to new pictures.
also a very precise work :)
