• 07.11.2026, 06:55
USB problems with current AMD chipsets (X370/X399)
Tuesday, March 19th 2019, 5:32pm
At the moment some customers reportiung problems using our devices with current AMD chipsets, especially X399, X370 and X470.
The problem is seen in the fact that the devices are present in the device manager and communicate normally with the computer. However, the transferred data is not transferred from the driver to Windows as intended.
All relevant payload data is missing. This error becomes obvious already during the installation of the aquasuite. In this case, a faulty USB communication to the device is displayed instead of the serial number. Without the serial number an installation of the aquasuite may not be possible.
The problem only occurs with Generic HIDs. Devices, such as the VISION series, which log several devices to Windows in parallel, operate without any problems with the other functions (mouse, keyboard, etc.).
The problems described here arise exclusively:
- AMD Chipsets X399 or X370/X470
- Using a USB hub
- Connection of more than two devices to the hub
- At least three devices support the Generic HID class
- Using Windows 10
In addition, not all root hub connections are affected. In contrast to the internal connections, the external connections of the motherboards usually work without problems.
Known solutions:
- Direct connection of the devices to the motherboard without using a hub
- Connection of less than 3 Generic-HID devices to a connected hub
- Using an external port for the hub (depends on the motherboard)
We will inform AMD about the faulty behavior and hope to be able to solve the problem in future drivers/BIOS versions. We have subjected our devices to intensive testing and analyzed the raw USB data. There are no known bugs here.
The described behavior also occurs with devices of other manufacturers. Thus different Hubs (NEC, NZXT etc.) were tested and also Generic HID devices of other manufacturers.
We are not able to solve this error from our side, because neither our devices nor the aquasuite can influence this part of the USB-communication.
Undesirable
Saturday, March 30th 2019, 7:24am
As I said 1 year and 10 months ago on these forums, Aquasuite Installation cannot detect even ONE SINGLE DEVICE (AQUAERO 6) CONNECTED TO THE HUB with the Crosshair 6 x370 and Hubby 7 internal USB hub.
Aquaero 6 Not Detected with Hubby 7
This post has been edited 2 times, last edit by "Undesirable" (Mar 30th 2019, 7:28am)
