• 09.10.2026, 02:55
mstern
Mounting D5 Next (with Ultitube) to 120mm Fan
Friday, July 17th 2020, 6:54pm
Trying to mount my D5 Next to my PC. I bought the 120mm fan mounting adapter (picture attached). The D5 Next and Ultitube came with a mounting bracket (the black L-shaped one) (picture attached).
None of the holes in the black bracket seem to line up in any way or orientation with the fan mounting adapter.
I would prefer mounting it to a vertically mounted fan, but if that's not possible, I also have a horizontally mounted fan I can use if needed.
I've spent hours searching these forums and googl'ing and had no luck. I may be missing something, because surely this shouldn't be this hard?!?
Any advice appreciated!
mstern has attached the following files:
  • bracket2.jpg (303.13 kB - 248 times downloaded - Last download: Oct 7th 2026, 1:08am)
  • bracket1.jpg (292.56 kB - 235 times downloaded - Last download: Oct 6th 2026, 12:12pm)
Friday, July 17th 2020, 7:03pm
The problem is that you are using the wrong mounting bracket at the fan side.
You need this one instead for the ULTITUBE: https://shop.aquacomputer.de/product_inf…855&language=en
Friday, July 17th 2020, 7:05pm
You have picked the wrong mounting bracket. Yours is for the ULTITOP but you need the one for the ULTITUBE.
edit: damn, too slow :D
mstern
Friday, July 17th 2020, 7:38pm
Thank you both so much! The responsiveness of AC folks is truly impressive and appreciated!
A bit sad that I got the wrong bracket. I really did try to read about them carefully and order the right one. So, mounting my pump will have to wait another week or so now to get the new bracket :(
Vielen Dank!
