• 29.11.2026, 08:57
mojmir
aquaero 6 + RGBpx LED ring
Wednesday, August 19th 2020, 11:51am
Hello,
i have an aquaero 6 lt, and i would like to "light up" my reservoir using product 53276 ( https://shop.aquacomputer.de/product_inf…roducts_id=3787 ).
What i would like to do:
I would like to correlate the rgb to that of temperature, i.e. so that aquaero controls the rgb on my res to temperature of the fluid.
Eventually buy two of these rings and do a gradient between temp before rad and after rad.
What do i need to connect to aquaero to be able to do that?
Best regards,
Mojmir
(i know it's a probably trivial question, but i want to avoid situation "you have everything, but one tiny cable is missing")
k2viper
Wednesday, August 19th 2020, 11:55am
Aquaero is not able to drive a RGBpx component. Its "RGB" output is not compatible with RGBpx.
You need one of the devices capable of RGBpx control: farbwerk 360, Quadro, Octo, D5 NEXT.
mojmir
Wednesday, August 19th 2020, 5:47pm
Hello, thanks for your response.
So i buy Farbwerk 360 and connect it to Aquaero via Aquabus?
Is there some kind of chaining of Aquabus? because i have already Cryos Next already connected to Aquaero.
k2viper
Wednesday, August 19th 2020, 6:01pm
Well, especially farbwerk 360 is not connectable to aquaero via aquabus :) Though it has aquabus port in hardware, it is disabled in firmware.
But, you still can have RGBpx effects based on sensors values of aquaero. I have both farbwerk360 and aquaero and I can assure you it's possible to create effects you described.
If you decide to go with farbwerk360, you do not need anything besides farbwerk360's package contents and your LED ring's contents.
You also may consider going with Quadro or Octo, they have their own RGBpx output ports and can be connected to aquaero by aquabus.
This post has been edited 1 times, last edit by "k2viper" (Aug 19th 2020, 6:04pm)
Hufeisen
Wednesday, August 19th 2020, 9:55pm
A Quadro or Octo can be connected with Aquabus to control the Fan speed, but it is not possible to control RGBpx with Aquabus. RGBpx requires an USB connection to work.
This post has been edited 1 times, last edit by "Hufeisen" (Aug 19th 2020, 9:59pm)
k2viper
Wednesday, August 19th 2020, 10:19pm
This is true, that's probably why farbwerk360 is not getting firmware with aquabus working.
Farbwerk360 can control its RGBpx effects depending on 4 thermal probes on itself, one flow sensor connected to itself, and 16 software sensors that can be imported through Aquacomputer service and Aquasuite from any system data source, including aquaero.
mojmir
Monday, August 24th 2020, 8:58pm
Quoted
what if i am using linux? (and therefore aquasuite is not running)
Hufeisen
Monday, August 24th 2020, 9:23pm
On Linux, you can only use hardware sensors.
You must connect a temperature sensor directly to the Farbwerk360 / Quadro / Octo.
Then you should be able to use this sensor as Input for your RGB Color. (i am not sure about this)
Color processing is done in the device, so the Aquasuite does not need to run all the time.
Aquacomputer Staff need to answer if the function for Temperature to RGB Color is available without USB connection.
This post has been edited 5 times, last edit by "Hufeisen" (Aug 24th 2020, 10:00pm)
Friday, August 28th 2020, 1:24pm
Yes, that works in the device too. So changing the LED color based on temperature changes is no problem. It only needs to be set up once via the aquasuite software. Afterwards it is stored in the memory and processed by the device itself. This only works with sensors that are directly attached to the controller.
