• 28.09.2026, 22:50
Spirti1976
[SOLVED]Aquaero 5 Pro / VISION USB problem
vendredi 15 juin 2018, 00:25
Hi, I have a problem since the 1st day I bought Vision/Aquaero setup. Maybe some people experienced the same.
I have:
Kryos NEXT VISION CPU block
VISION for GPU block
MPS flow 400
Aquaero 5 Pro
HUBBY 7
So, HUBBY 7 is connected to motherboard's USB 2.0, all other USB devices plugged into HUBBY. Flow 400 connected to HUBBY and to Aquaero by Aquabus to HIGH (actually the connection of mps doesn't matter, I tried all combinations and even without mps). Aquaero is configured to read the sensor information from Aida64 (used HWinfo as well, same effect). Latest firmware, tried to reset the Aquaero to defaults.
The problem is:
When I turn on the PC in the morning (I shut it down using Windows shut down but PSU remains is in standby) - Aquaero is not getting any info (even mps flow 400 which it reads from the sensor itself) from Aida64/Hwinfo but all Aquacomputer devices are recognized in Aquasuite. I do a simple reboot and everything works just fine. And I have absolutely the same issue on my other PC which has Aquaero only.
This happens every day. I used 2 motherboards on my main PC - same effect.
Windows version doesn't matter - all the same on 7, 8.1, 10.
I got used to it but I think it shouldn't be this way.
Any help much appreciated. Thanks.
Looks like Aquasuite 2018.1 solved the problem. Thanks!
Ce message a été modifié 2 fois. Dernière modification effectuée par "Spirti1976" (9 juillet 2018, 08:58)
Spirti1976
dimanche 17 juin 2018, 23:00
mardi 19 juin 2018, 11:25
It's a known USB problem and should be fixed with aquasuite 2018 (~2 weeks).
Spirti1976
mardi 19 juin 2018, 13:47
Thanks!
