Sie sind nicht angemeldet.
Aida has an very limited data export. Hwinfo provide for the most values a unit.the Watt units are there, but all the % unit's are missing. They are present from HWiNFO.
Just download Aquasuite from the top of the first page. Should be a link there. It comes with details on what was fixed, changed, etc. and what hardware the update refers too. If you have one of these products, than yes, this would include you.Ok, what all do I need to run this controller? I see all kinds of names on that 1st post (Aquasuite, Aquaduct, Aquastream Ultimate). I downloaded the Aquasuite software linked on the 1st page, is that all that's needed to run this controller or is there other software that needs to be downloaded in addition to what's linked on the 1st page?
Thanks
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »barfly« (14. April 2016, 18:24)
I meant the software sensor feature of the aquasuite
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (15. April 2016, 00:01)
another issue that bugs me more tho is every software version ive used is when im locking/unlocking or saving a profile i have to wait 5-8 seconds for this to be done,upping the process level helps some but shouldn't be needed.
possibly but it does the same on both builds and their both with high end parts,ill run a vid and show the issue as the 6-8 lag is prominent on both and during that time aquasuite says ''not responding''another issue that bugs me more tho is every software version ive used is when im locking/unlocking or saving a profile i have to wait 5-8 seconds for this to be done,upping the process level helps some but shouldn't be needed.
Must be a strange problem caused by your system because it works fine here and I have a pretty slow system at work.
HI i use no software sensor, i only use the aquasuite for controlling my pump.
