 31.10.2025, 20:09
31.10.2025, 20:09 Sprache ändern
 Sprache ändern
						 Registrieren
 Registrieren Anmelden
 Anmelden
											Sie sind nicht angemeldet.
																														 Greensmack
																		Greensmack
								Sonntag, 27. Januar 2019, 17:27
																														 levifig
																		levifig
																														 Hufeisen
																		Hufeisen
You could create a Y-Cable to connect 2 Splitty4 to a single Quadro.can we just join 2 RGBPX cables from 2 splitty 4 to 1 Quadro?
Dieser Beitrag wurde bereits 13 mal editiert, zuletzt von »Hufeisen« (7. Februar 2019, 00:57)
																														 Hufeisen
																		Hufeisen
I dont know, there is no information about this in the Manual of the Quadro.Can it power 84 leds?
It should work in theory.can I join the 2 RGBpx cables to connect then to a single Quadro?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Hufeisen« (7. Februar 2019, 00:53)
																														 levifig
																		levifig
Why isn't there an official way to connect multiple Splitty4s to a single Quadro? For example: I have 3x Splitty4s, controlling 12 ML120 PRO RGB. They have 4 LEDs each, so 12x4 is exactly 48. This is under 64... I'm incredibly surprised how this wasn't supported from the beginning, honestly. :oThe quadro can control 64 leds. when you connect more. the leds are not controlable.
If you connect more than 64 LEDs (multiple Strips with y- cables) then the maximum current capability of the hardware is exceeded.
You can damage your hardware if you connect the strips in a different way than the one described in the manual.
You can connect as many devices as you want via USB. Only via aquabus can you connect only 2 to an aquaero.
																														 levifig
																		levifig
each one ML pro RGB fan contains 12 leds, so 4 fans = 48 leds, you cannot use 3 x splitty 4 as I was reading without a Quadro for each one, you need a Quadro for each Splitty 4
																														 levifig
																		levifig
Since I have only one USB 2.0 motherboard header, I was told I will have communications issues if I chain two HUBBY7s to each other for more USB inputs.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »levifig« (14. Februar 2019, 05:44)
Honestly, you'll be better off buying an NZXT internal USB 2.0 hub. They're about $20 and give you 3 internal headers (off of a single one) + 2 USB-A ports. They work great (I use them).
																														 levifig
																		levifig
Other theoretical options (i dont know if these actually work, but they should work in theory)can we just join 2 RGBPX cables from 2 splitty 4 to 1 Quadro?
You could be able to chain two Splitty4. This allows you to connect more than 4 Fans to a Quadro.
for this you need to solder three cables to the correct pins on the back side of the first Splitty4 and connect these to the second Splitty4.
							Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »levifig« (19. Mai 2019, 23:09)
 English forum »
 English forum » RGBpx wiring Diagram
											(22. September 2018, 03:59)
										 English forum »
 English forum » NEW: QUADRO and RGBpx Splitty4
											(29. Juni 2018, 11:28)
										 Wasserkühlung »
 Wasserkühlung » Neu: QUADRO und RGBpx Splitty4
										 English forum »
 English forum » NEW: aquasuite 2018
											(29. Juni 2018, 11:23)
 NEW: aquasuite 2018
										 Überwachung und Steuerung »
 Überwachung und Steuerung » Wie 12 Corsair Lüfter und 4 RGBpx-LED-Stripes steuern?
											(30. September 2018, 12:43)
