• 22.03.2026, 23:33
fluff34567
Englisch- what is this block?
Montag, 24. Mai 2004, 13:39
hallo,
sorry my german is not good so i write in english.
i have a block made by aqua - can someone tell me the model , when it was made?
[img]http://www.ocforums.com/attachment.php?s=&postid=2782962[/img]
i also need to get some attaching screws to hold it to the board - what is a good online shop to use??
thankyou in advance
Dino
Re: Englisch- what is this block?
Montag, 24. Mai 2004, 13:40
This waterblock was never made by us. It looks selfmade.
Dino
pharao
Montag, 24. Mai 2004, 13:42
Is the writing carved into the Glass, or into the Copper?
fluff34567
Montag, 24. Mai 2004, 14:05
Many thanks for the replies !
the "aqua" is in the copper - it has been machined on a computer controlled machine so dont think it will be homemade. it is a very strange design block but i will try it in my system and see how well it works.
ThaDog
Montag, 24. Mai 2004, 20:36
I've seen this Waterblock for about a year ago on Ebay.....
It was build from a guy who had access to a CNC machine ( correct me if i'm wrong ).
He sold several of this type and then it vanished from Ebay and i have never seen it again, until now  :)
I tought that the design of the block was pretty cool cause of the "Aqau flow channel" inside the block.
cya
ThaDog
fluff34567
Montag, 24. Mai 2004, 23:48
cya
ThaDog
ah ok - thanks for the info! the "aqua" confused me a little LOL i will see how well it works - some luft gets trapped behind the letters but not much.
ill let u know how it works when i get it running.
Al_Borland
Dienstag, 25. Mai 2004, 01:48
the air bubbles should disappear, when using the block for a while. ;)
Gruß, Micha.
FredFruchtig
Dienstag, 25. Mai 2004, 01:57
??? ;D
Zitat von »Chewy«
fluff34567
Dienstag, 25. Mai 2004, 18:54
Zitat von »FredFruchtig«
 ???  ;D
and your point is?????
HeaDFraG
Dienstag, 25. Mai 2004, 20:23
I think he doesnt understand why you use the word "luft" instead of "air", so do I. Is this a common expression of the watercooling scene in other countries?
fluff34567
Dienstag, 25. Mai 2004, 23:33
no not at all - its just that i am learning german at the moment and sometimes words slip into my sentances.
