• 07.05.2026, 06:59
Frode B. Nilsen
Aquaero 6 and EKWB D5 G2
Dienstag, 21. Februar 2017, 16:44
There is upgraded version of the D5 at EKWB, the G2 version. Does this work with the Aquaero 6?
The main benefit of the EK model, is its low speed of 800rpms as opposed to the 1350RPM of my Aquacomputer model. I need that feature, to combat noise.
Anyone tried that pump?
GTXJackBauer
RE: Aquaero 6 and EKWB D5 G2
Dienstag, 21. Februar 2017, 17:50
The main reason is having the D5 pump within intel's PWM spec as the previous pump wasn't or most of the PWM D5 pumps out there. Because of this, the G2 (Generation2) will work with the AQ6.
