• 11.04.2026, 04:23
rmchl
D5 Next RGBpx control
Freitag, 28. Dezember 2018, 23:48
I have 2x RGBpx 15x LEDs chained to the D5 Next installed on an aqualis top. When I power the system, because I have the pump off, the D5 goes into low pump alarm. flashing red and beeping. Is it possible to silence the alarm? The buttons do not seem to be responding. I want to test the RGBpx as the build is still in work (mobo not installed, dry) or does it require aquasuite to configure?
Samstag, 29. Dezember 2018, 08:23
Have you installed the newst aquasuite 2019-9?
no, you cant disable system alarms
rmchl
Sonntag, 30. Dezember 2018, 03:29
Just plugged the D5 Next into my laptop and installed aquasuite. Updated the firmware. RGBpx working... flashing red due to the low pump alarm.
Thanks
