• 08.01.2026, 07:48
taloche3
Lot of aquaero 4.00
Freitag, 15. Februar 2019, 10:42
Hello,
I have 4 aquaero 4.00 who don't working on actual mother board, but working well on older mother board. Of course, i try with a lot of USB adapter, but finaly i found in this forum the root cause : Aquaero 4.00 are not compatible with modern mother board. I don't kwown where is the fault, all motherboard side, aquacomputer side, or something else, i dont care.
But what can do with this 4 quaero ?
Have you a solution to made working ? If not, they go to trash.
mditsch
Freitag, 15. Februar 2019, 12:34
see here.
working USB Card for Aquero 4 and modern MoBo's
Sorry, is in german, but maybe it helps to follow the URL's
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »mditsch« (15. Februar 2019, 12:42)
taloche3
Freitag, 15. Februar 2019, 14:21
Thanks for answer.
I have a mini ITX motherbord, so i don't have PCI free slot. maybe it is working with a no PCI ( usb ) card with ASMEDIA 1142 Chip, but i don't found it.
I buy another solution to monitoring my loops, and i forget aquaero 4.00. Anybody interest before i put it in trash ?
thanks again for the link.
