• 22.02.2026, 00:30
Storm1760
setting up Octo
Dienstag, 5. Januar 2021, 13:57
Hi I have a Octo conroler and would like to know If you install the Aqusuite software or the octo controler first.
also the Aquasuite software page says "To use the software, Microsoft .NET Framework 4.6.1 must also be installed.The .NET Framework is already integrated in current Windows versions"
I am running windows 10 and have .NET Framework 3.5 and 4.8 so am I right that you do not need to install Microsoft .NET Framework 4.6.1 ?
sorry if this has been covered else where in the forum or its a stupid question I just want to get it right
Many thanks for your help
Dienstag, 5. Januar 2021, 14:12
Net 4.8 is fine.
Install the octo and connect the device vis USB and install the aquasuite.
Storm1760
Dienstag, 5. Januar 2021, 14:17
Thank you for the Quick reply and answers ! :D
