• 23.03.2026, 12:24
klara
[bug report] Flow rate in l/m does not work
Sonntag, 28. August 2022, 10:28
Since high flow NEXT only supports l/h for unit of flow rate, I made a virtual sensor to display it in l/m.
Here, you can see the Flow rate virtual sensor reports the output value in l/h, even though the out block in diagram reports it in l/m.
WinstonWoof
RE: [bug report] Flow rate in l/m does not work
Sonntag, 28. August 2022, 11:27
Verified plus another oddity noted
https://www.youtube.com/watch?v=_6dHGV7u0eM
Sonntag, 28. August 2022, 12:37
According to sebastion there are two values that may not be altered in the virtual sensor module, flow rate and temperature.
WinstonWoof
Sonntag, 28. August 2022, 12:42
Interesting but how come if I change the output unit to l/h it shows the calculated l/m value just with the l/h value ?
(see last part of my video)
Feels more like a bug than a feature to me :)
Remayz
Sonntag, 28. August 2022, 13:52
you have to change the displayed unit in Aquasuite options directly (meaning losing L/h display).
It's one or the other :)
Edit : nevermind, the link aswered that already
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Remayz« (28. August 2022, 13:53)
