• 11.01.2026, 07:24
profanum429
Leakshield with Multiport Ultitube Lid
Sonntag, 13. Oktober 2024, 00:06
I’ve recently converted over to an Ultitube and swapped to the multiport top where my top radiator connects to the reservoir. I was interested in getting a Leakshield; I’d need to do the external Leakshield and can connect it to the second port on the multiport top but I’m concerned that the pressure relief valve in the Ultitube top will not allow the Leakshield to function, assuming its an equalization valve and not just for over pressure. Is that a correct assumption? I’ve looked and haven’t really found any definitive posts on it.
Disregard, my google fu wasn’t up to par! Looks like I’ll be trying to block off the pressure equalization valve.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »profanum429« (13. Oktober 2024, 00:55)
