• 10.02.2026, 20:02
Krutors
Question regarding data sources from the Aquacomputer Hardware Monitor - RAM temperature
Freitag, 16. Mai 2025, 03:57
I would like to know if it's normal that RAM temperature is not reported in the "Hardware Monitor" section, or does it have to do with my setup combination ?
Said temps are reported fine in HWInfo, but I don't seem to be able to make them show as a potential data source (I use the free version tho)
I would like to be able to add those as a custom sensor to tie some of my fans' speed to it, as DDR5 can get quite toasty, especially when OCed
Rig :
MSI X670E board,
2x16G of Corsair memory
Feel free to ask anything you think is relevant.
murakume
Samstag, 17. Mai 2025, 05:50
Shared memory support enabled in hwinfo? It’ll be in the main settings, not the settings you get from the sensors panel. Since you’re using the free version you’ll have to re-enable every 12 hours or something like that I think. If you’ve already done that I’m not sure lol
Krutors
Samstag, 17. Mai 2025, 16:54
Thanks, I forgot shared memory was available for trial in the free version.
I think I'm gonna fork some money for the pro version.
n3rz001
Sonntag, 15. Juni 2025, 07:34
I havie aida 64 and if you enable the shared you don t have to recheck every 12 h as Hinfo
