• 19.12.2025, 10:31
brandofriva
RGB Twinkle Effect / Custom Effects
Tuesday, December 22nd 2020, 11:27pm
Looking for an effect similar to Razor Chroma's Starlight effect (random twinkle on LEDs). Or is there some way to do a custom effect to achieve this?
brandofriva
Monday, December 28th 2020, 6:43pm
No-one have any ideas on how to achieve this effect?
Its just great as it will look good/consistent across any length of strip.
Monday, December 28th 2020, 7:01pm
In farbwerk 360 / nano we have different effects like this,... you have to try out what konfiguration for you ist the best,
Every effect can be adjusted in many ways.
brandofriva
Monday, December 28th 2020, 7:10pm
Are the effects on the Farbwerk 360 different to the Octo?
Tasky
Monday, December 28th 2020, 7:18pm
I generally find the Farbwerk series has all the same effects as everything else, plus seven or eight extra ones that are only available on Farbwerk devices.
brandofriva
Monday, December 28th 2020, 7:38pm
Thanks very much! I have a Farbwerk 360 on backorder from a local store. Hoping it supports this :)
