• 09.01.2026, 05:11
gamblodar
3090 Power Draw Reporting
Mittwoch, 10. März 2021, 08:06
When adding a guage to the display, I am unable to select the power draw from my RTX 3090 using Aqua Computer Hardware Monitor, I must use HWinfo. The card is listed, but the power draw is not one of the sensors for use.
How can I fix this issue?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »gamblodar« (10. März 2021, 08:07)
Mittwoch, 10. März 2021, 08:13
This is no issue, the aquasuite dont support this value. When you need this value, you have to use a software like aida or hwinfo.
gamblodar
Mittwoch, 10. März 2021, 08:14
I understand.
Can you help me understand why it removed from AquaSuite, because it used to be there?
cptninc
Freitag, 12. März 2021, 13:22
It is there in X.36. Was it removed in X.37?
[img]https://forum.aquacomputer.de/index.php?page=Attachment&attachmentID=8255&h=7d84eb445acc3e02380dce497b5cb99ce712659c[/img]
»cptninc« hat folgende Datei angehängt:
  • Untitled.jpg (70,02 kB - 190 mal heruntergeladen - zuletzt: 5. Januar 2026, 20:07)
Freitag, 12. März 2021, 19:55
The nvidia driver has memory leaks and problems when we use the nvidia api to readout this value. We have removed this value permantly from our monitoring.
k2viper
Freitag, 12. März 2021, 20:27
Is Nvidia aware of the problem with the driver and will it be fixed any time soon?
Again I ask you to return this value as a disabled-by-default option for those users who do not have latest Nvidia GPUs and drivers.
cptninc
Samstag, 13. März 2021, 16:04
Is there another method that you could use to get the data? I can think of a dozen applications off the top of my head which are able to display this data without memory leaks.
Power draw is very useful data when troubleshooting a system. It would be nice to have it in the same place as the cooling data rather than having to load up an additional app to see it.
biopunk
Samstag, 13. März 2021, 22:01
Damn, that's really unfortunate. There I was, happy that I no longer had to run HWINFO in background all the time :(
