• 15.10.2026, 22:50
mardi 11 septembre 2018, 17:08
Its a problem that we are already aware of ;)
Hufeisen
mardi 11 septembre 2018, 21:33
Is there any settings I miss to start the tack signal sooner, so the mobo will not stop the POST and avoid the error... is quite annoying.
You can disable the CPU Fan error message in the mainboard BIOS.
in BIOS, go to Monitor Tab and set CPU FAN Speed to [Ignore].
Ce message a été modifié 1 fois. Dernière modification effectuée par "Hufeisen" (11 septembre 2018, 21:34)
smeroni68
mardi 11 septembre 2018, 22:33
Yes, that is the easy way to avoid the error... but don't you think that RPM signal is used in my settings into Aquasuite to manage for example the shutdown in case of any problem problem on the cooling circuit?
I highlight the problem, because I think that on firmware side, the RPM signal generation must be active from the first second of Aquaero poweron... the boot of the controller has a duration of some seconds and in this period the RPM is not generated... my motherboard is faster than the controller boot so the error come up.
Anyway thanks for the hint.
Elderdeekey
Labels gone?
jeudi 11 octobre 2018, 15:20
I've just updated to 2018-6 version from 2017 one. No problem so far except some of my labels lost its color (and went white).
I am able just to recreate all of them (and I've noticed xaml hanges in preset text) but vertical ones.
Let me explain - the old labels' code was like this:
x:Name="this"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:sys="clr-namespace:System;assembly=mscorlib"
mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="300">
Sensors
Sensoren
Content="{Binding Converter={StaticResource LanguageConverter}, ConverterParameter={StaticResource myTexts}}"
Opacity="1.0"
Height="Auto"
Width="Auto"
Foreground="#FFaf0115"
FontSize="45"
FontFamily="Segoe UI"
FontWeight="Normal"
Margin="0,0,0,0"
Padding="0,0,0,0"
HorizontalAlignment="Left"
VerticalAlignment="Bottom">
However text is always white, but could be rotated with Label.LayoutTransform
The new one is:
x:Name="this"
Text="CPU"
Opacity="1.0"
Height="Auto"
Width="Auto"
Foreground="#FF011ffe"
FontSize="22"
FontWeight="SemiBold"
Margin="0,0,0,0"
Padding="0,0,0,0"
HorizontalAlignment="Center"
VerticalAlignment="Center"/>
It changes colors but I cannot rotate it with LayoutTransform.
Any hints on how to fix it?
Elderdeekey a envoyé le fichier suivant :
  • WHITELABELS.JPG (53,41 kB - téléchargé 532 fois - Dernier téléchargement : 12 octobre 2026, 09:21)
jeudi 11 octobre 2018, 16:12
Use Textblock instead of Label.
Label has to much overhead.
Elderdeekey
vendredi 12 octobre 2018, 17:08
I do but those are your examples, taken from mps devices.
Meaning incompatibility between 2017 and 2018 versions in that area.
Shoggy NEXT
lundi 22 octobre 2018, 14:47
aquasuite 2018-7 is online.
Changelog on first page (second post).
Dundys
lundi 22 octobre 2018, 17:17
Installed new aquasuite 2018-7, so far no issues to report.
Thanks
lundi 22 octobre 2018, 18:56
Also installed 2018-7 sans issue, other than having to reactivate windows services.
Slightly disappointment no corrections to gauge objects, particularly numeric text size option.
mardi 23 octobre 2018, 07:45
The gauge objects works as designed.
mardi 23 octobre 2018, 14:39
Ed.Dark
jeudi 25 octobre 2018, 16:25
I've always had a problem with the app becoming invisible whenever i go to the desktop (WIN+D). The app is still running in task manager and the only way to see it again is to force close it then relaunch it...
Any clues. It happens whatever version I run....
ewolwerd
Manual
mardi 30 octobre 2018, 01:08
Sorry, I am sure that I am overlooking it, but I have searched everywhere for a manual or guide to the aquasuite software. Can someone point me in the right direction? I have it working with my new quadro, but I would like to see some explanation of how more advanced option work.
RE: Manual
mardi 30 octobre 2018, 05:54
Chapter 8+ in the aquaero manual covers the aquasuite.
novax1
Hardware monitor
mardi 20 novembre 2018, 11:38
Greetings to all told that they would support monitor hardware. After two updates, it remains the same, nothing has changed.
it also does not detect the SSD.M2 disks.
with the same temperatures are not correct.
RE: Hardware monitor
mardi 20 novembre 2018, 15:34
Hardware monitoring is not the aquasuite's forte, and is implemented only for common, core elements of a system.
If you want to see a more complete sensor list in the aquasuite, you should use the free HWiNFO utility.
novax1
RE: RE: Hardware monitor
mardi 20 novembre 2018, 18:32
Thanks for your help but then what I show in the image is not at all.
I do not want to insist on this but if to show system data I have to have two programs running.
When aquasuite the possibility of not using an external program.
our image of the support that is supposed to remain.
Thank you
novax1 a envoyé l’image suivante :
mercredi 21 novembre 2018, 05:09
I may be missing the intent of your comment due to translation, but you can use aquasuite to display sensor values from HWiNFO.
When adding an object (i.e. gauge) to a display page, if HWiNFO is running, you can select the source for the object from the sensors under the HWiNFO tab.
EDIT: If you are looking to integrate with your aquastream ULTIMATE, watch this aquacomputer video at 2:20.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (21 novembre 2018, 06:39)
Hopper64
mercredi 13 mars 2019, 23:14
Just noticed the new 2018-10 version today and installed it, but the version number in the top left of the software still says "2018-9". Have I installed it incorrectly? Thanks.
jeudi 14 mars 2019, 04:39
Please, please, PLEASE, have the aquasuite check for updates and give notice if an update is available.
This 2018-10 update appears to have fixed several bugs, and yet nobody knew... an accidental discovery.
