• 30.11.2026, 22:56
j_afc
cuplex kryos NEXT with VISION
vendredi 19 juin 2020, 07:35
I set the alarm function to shut down the computer, when the cuplex kryos NEXT with VISION is connected to the usb windows shuts down before i can reset it.
Is there a way to reset the cuplex kryos NEXT with VISION to default settings before the alarm shuts down my pc?
vendredi 19 juin 2020, 14:15
Remove the USB connection of the block and go to the Windows control panel -> hardware and sound -> power options -> system settings
There are two entries for actions. Set both to do nothing.
Here is a screenshot as reference so you know what you are looking for:
Shut down the PC, plug in the USB cable again and change the temperature value. Afterwards you can set the mentioned actions back to its previous settings.
