Sie sind nicht angemeldet.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (13. Februar 2016, 01:22)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Kyle XY« (20. Februar 2016, 21:15)
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »GTXJackBauer« (14. März 2016, 20:56)
this is a bigger change in the aquasuite data handling - we have this and some other features in plan.And a minor disappointment that errant/missing sensor units correction/addition was not addressed.
this is currently when we cant read a valid unit. we are in contact with the aida64 team.I noticed a couple anomalies regarding Sensor Units transferring from Aida64 via Shared Memory.
Some Units that should be Watts or % are all showing as Volts by aquasuite.
.. try to replace this dll (unzip the zip file)
in the folder:
Quellcode
1 C:\Program Files\aquasuite\Plugins
replace the file:
Quellcode
1 PluginImportAida64.dll
[attach]5645[/attach]
I have the Aquero 6 Pro. I went through some hell when I updated to 2016 - 3 from 2014/2.3. I did the update on top of 2014, didn't uninstall it but it wasn't running.
The problem started when everything went 100%, fans and pump. The firmware never succeed to update so I couldn't use the program. I managed to find my old software 2014, installed it, but no features in the aquaero tab where showing up, so I couldn't roll back and use it. System restore didn't fix it either. I deleted the software and installed 2016 - 3 again, did the firmware update and succeed, now I have to fix my old fan/pump settings.
Please advise how to update the software so it don't happen like this again.
