• 01.11.2025, 03:20
Xaqua
Vision terminal for kryographics installation issue
Freitag, 20. März 2020, 03:32
The connection terminal middle hole counter-bore I.D. is smaller than the screw-head O.D. :huh: I machined 0.25 mm off the screw to get it to fit. Serious problem potential for the average user.
Freitag, 20. März 2020, 10:19
Sorry to learn about this problem. This does not seem to be a general issue. I checked items from stock and they are fine.
Maybe you have been unlucky and received a faulty machined screw.
