• 31.01.2026, 08:44
cesarnono13
Replacement o-rings for Cuplex Kryos NEXT with VISION 1151 acrylic/nickel
Freitag, 22. Mai 2020, 21:23
I am looking for replacement o-rings as my current CPU block is losing pressure after disassembling it for cleaning.
The o-rings I found are : https://shop.aquacomputer.de/product_inf…roducts_id=3381
and
https://shop.aquacomputer.de/product_info.php?products_id=3734
I just wanted to make sure these will work because the description in the o-rings doesn't specify NEXT and I am under the impression that the NEXT might be a different baseplate design.
Additionally, I am in the United States, so shipping for these via the checkout is via USPS and its a ridiculous amount.
The only vendor that seems to have these in stock in the US is performance pcs, but they dont seem to have the aquaduct filter gasket available. Any other ideas where to source the product?
Thank you in advance.
Samstag, 23. Mai 2020, 00:13
To make sure you selected the right items, you should directly write to support@aqua-computer.de.
As I see in the shop, there is a option for shipping small items:
International shipping fees outside the European Union:
All countries: Small orders up to a weight of 125 g and a maximum value of € 50.00 can be shipped in a padded envelope for € 5.00 (VAT-exempt) per order.
Shipping Costs
cesarnono13
Samstag, 23. Mai 2020, 01:05
Thank you. I wasn't aware of this shipping option.
I will be sending them an email.
Shipping Costs
cesarnono13
CORRECT Replacement o-rings for Cuplex Kryos NEXT with VISION 1151 acrylic/nickel
Montag, 25. Mai 2020, 19:21
I wanted to share this information in case someone needs this in the future.
According to an aqua computer representative who replied to my email, the aqua computer shop did not have the o-rings listed for the Cuplex Kryos NEXT with VISION, but they do now.
THESE are the correct o-ring replacements for the CPU block (Notice the date these were added to the shop):
https://shop.aquacomputer.de/product_inf…roducts_id=3901
and
https://shop.aquacomputer.de/product_inf…roducts_id=3900
I hope this helps someone who is in my situation.
Cheers!
