• 20.11.2026, 12:54
neuer Benutzername
Thursday, January 18th 2024, 2:34pm
sieht bei mir genauso aus:
da kurz nach dem Einschalten des Systems Uhrzeit und Datum da sind und Aqua Suite ja erst später geladen wird, hätte ich mir gewünscht wenn die Daten anhand des aktuellen Datums / Uhrzeit auch in der Liste auftauchen würde. Leider ist dem nicht so.
Ich kenne diese Anzeige gar nicht anders wie oben zu sehen.
Mein Leakshield hängt an einem externen USB Hub welcher über SATA mit Strom versorgt wird. Wenn ich den Rechner ausschalte, wird der Strom von SATA ebenfalls abgeschaltet und bei mir ist Leakshield stromlos.
lqx4684
Sunday, January 21st 2024, 2:20pm
Hello team, this is my first post here, i hope I'm in the right section.I have an Ultitube LS 150 but i can't get the LED strips to work, do you have any advice please?
the LED strip is connected to the pump, i looked on the software but i never managed to get it to workThank you and good day
This post has been edited 1 times, last edit by "lqx4684" (Jan 21st 2024, 3:13pm)
PvF
Monday, January 22nd 2024, 4:06am
The LED-Ring has an "in" and "out" marking - be sure to connect the cable to the "in" Port.
The connector at the Pump is also very tiny - is the cable plugged in correctly?
Could you provide us a screenshot of the RGBpx Tab from your aquasuite? There should be two "LED configuration Lines" at the top - one marked with "Pump" and the second with "Strip"
lqx4684
Monday, January 22nd 2024, 12:29pm
The connector is well connected, and it is also well connected to the "in" i have never managed to get it to work
lqx4684 has attached the following file:
  • Sans titresdsd.jpg (118.84 kB - 2,197 times downloaded - Last download: Yesterday, 12:37pm)
lqx4684
Monday, January 22nd 2024, 12:38pm
Ooooh !! I succeeded!! :D :thumbsup: I modified this:
I would still like to know what these 3 options represent?
  • sdqsdsDQSfd.jpg (142.59 kB - 6,981 times downloaded - Last download: Today, 10:45am)
PvF
Monday, January 22nd 2024, 1:33pm
If you don´t connect the pump or other devices to the mainboard via USB and have an aquaero, the devices can exchange data via the so called "aquabus". You can assign one of two addresses to the D5 Next within the "aquabus" if you have a second Pump.
You have already figured out the third point yourself. The output is then not used as a bus interface but for controlling the LEDs.
The connection to the aquaero via aquabus has the advantage that it also works under Linux, for example, but then you are not able to control an additional LED stripe (as you already know)
lqx4684
Monday, January 22nd 2024, 4:52pm
Thank you so much for your reply
This post has been edited 1 times, last edit by "lqx4684" (Jan 23rd 2024, 11:19am)
Kanye23
Tuesday, January 23rd 2024, 8:17pm
Hallo liebe Community,
(Vor weg System ist Dicht Membrane bereits ausgetauscht aus verdacht)
(Dichtheitstest mit einem Testo Gasabdruckgerät gegen geprüft^^)
(Bei Stabilen Umgebungstemperaturen und System auslastung über mehrere
Std Leak Indikator etc. bei 0ml) (Genauso wie bei meinem Testo
Abdruckgerät der geeicht ist) gehe also sehr sicher davon aus das es
keine Undichtigkeiten gibtUnterdruck über Test funktion geht auch über 400 mbar.
Habe gleich 2 bzw 3 Probleme
1.Wen ich den Shield Modus aktiviere und ich mir das Diagramm ansehe
(ihm Status) bzgl. Minimaler Maximaler Sollwert Druck baut Leakshield
den druck immer minimal unter dem Sollwert den Druck auf) (neuste
Firmware ist drauf) Also zb. Sollwert 305mbar Minimalerunterdruck
255mbar Maximaler Unterdruck 465 mbar. Shieldmodus pumpt allerdings nur
280mbar auf macht also nicht den Sollwert bzw geht zwischen Max und
Sollwert wo er vermutlich liegen sollte.
2. Irgendwo meine ich gelesen zu haben das man den den Druck manuell
eingeben kann also nicht adaptiv wo genau bzw. wie mache ich das
3. Beim System herunterfahren löst der Alarm ab und an mal aus ...
(könnte daran liegen das wen die Pumpe abschaltet der Druck abnimmt und
weil die Spreizung zwischen minimaler und sollwert zu gering ist)
(Habe da auch ein verdacht das beim System herunterfahren irgendwie
Probleme macht mit der Software meine auch hier schon gelesen zu haben)
Falls mir jemand helfen könnte wäre ich sehr dankbar ;)
neuer Benutzername
Wednesday, January 24th 2024, 12:46am
Quoted
Wen ich den Shield Modus aktiviere und ich mir das Diagramm ansehe (ihm Status) bzgl. Minimaler Maximaler Sollwert Druck baut Leakshield den druck immer minimal unter dem Sollwert den Druck auf) (neuste Firmware ist drauf) Also zb. Sollwert 305mbar Minimalerunterdruck 255mbar Maximaler Unterdruck 465 mbar. Shieldmodus pumpt allerdings nur 280mbar auf macht also nicht den Sollwert bzw geht zwischen Max und Sollwert wo er vermutlich liegen sollte.
Dann wird das vielleicht daran liegen das der Wert von deiner Pumpengeschwindigkeit, Gehäusetemperatur, Temperatur der Kühlflüssigkeit, Fließgeschwindigkeit der Kühlflüssigkeit genau diesen Wert benötigt. Halt adaptiv. Wenn du die Pumpe auf 20% laufen lässt, dann wird das Leakshield auf den entsprechenden Unterdruck eingestellt. Drehst du die Pumpe auf 100% hoch, dann wird automatisch der Unterdruck auch mit nach oben angepasst. Drehst du die Pumpe runter, bleibt der Unterdruck aber auf dem Wert stehen. Also es wird kein Unterdruck nach unten reduziert.
Gibt ja so den ein oder anderen der seine Pumpe nach Wassertemperatur regulieren lässt. Ich nutze lieber feste Werte.
ich habe das bei mir so eingestellt:
bei dir musst du dann den Haken bei Adaptiv entfernen.
oben rechts in der Ecke ist das Zahnrad - dort sind die Einstellungen vom Leakshield. Bestehende Einstellungen bearbeiten und dann bei Druck anpassen. Musst mal gucken was für Werte bei dir passen. Aber pass auf das du keinen zu hohen Unterdruck bei Schläuche machst. Laut Infos, die ich finden konnte, sollte man nicht über 450Mbar gehen da dies mit einigen Komponenten Probleme machen könnte. Ich habe bei mir Echtglasröhre verbaut und bin da mit Drücken relative safe.
Wenn der Unterdruck nicht zu deinem gewünschtem Wert aufgebaut wird, kannst du das per Hand "erzwingen" indem du hingehst und beim Leakshield Menu auf "Test" klickst, dort deinen Wert eingibst, den Unterdruck aufbauen lässt und beim erreichen des gewünschten Unterdrucks den Test abbrichst. So mache ich das immer.
Regelmäßig wird eine Füllstandsmessung durchgeführt wo der komplette Unterdruck abgelassen wird. Das ist auch wichtig für die Membrane damit die sich nicht fest setzt. Nach jeder Füllstandsmessung musst du den Druck dann zur Not wieder auf deinen Wert anpassen.
Quoted
von welchem Gerät? Durchflusssensor, Pumpe? Leakshield?
Kanye23
Wednesday, January 24th 2024, 4:29pm
Danke erstmal ;)
Leakshield gibt ab und an mal den Alarm aus er füllt auch nicht den unterdruck nach wen der pc aus ist nur wen das system läuft
neuer Benutzername
Wednesday, January 24th 2024, 7:57pm
dazu kann ich leider nichts sagen da ich noch nie einen Alarm hatte und irgendwie nicht nachpumpen muss :S
bleibt dein Leakshield an im Standby oder geht es aus?
vielleicht können die anderen User dir einen guten Tipp geben :rolleyes:
DaLiu
Friday, May 10th 2024, 2:13pm
I changed my water in the system yesterday and I have a problem with Leakshield detecting the water level in the Ultitube 150, he says its only 29% full when in reality its most likely to be 60% full, how can I fix this?
DaLiu has attached the following file:
Friday, May 10th 2024, 2:25pm
The LEAKSHIELD measures the entire water circuit and therefore also records all the air in the circuit.
If your system is completely vented, it should look better.
Piopi
Sunday, April 27th 2025, 5:33pm
Hello everyone! Can you please explain what each graph in the picture means, circled in red squares.
I have two circuits installed, one for the processor and one for the video card. Everything is connected with copper tubes (partially flexible tubes).
On the second lickshield (video card), the negative pressure reaches minus 600 millibars, although the upper threshold is 465 millibars in the settings. This happens during games. The water temperature rises from 28 degrees to 33, the pump speed rises to 4800.
I would appreciate your help
DeeSea
Sunday, December 14th 2025, 2:19pm
ich habe mir gestern die Ultitube 150 D5 Pro mit Leakshield als Herz für EKs aktuellen CPU und GPU Block über 2x420iger Radiatoren bestellt.
Aktuell habe ich das System mit 13/10 EPDM "vorgeschlaucht". Mir ist bewusst das der Leakshield hier im Protect Mode die Schläuche zusammenziehen würde. 16/10 EK EPDM Tube und 16/10 Fittings sind bereits auf dem Weg, aber meine Frage ist, welche Modi des Leakshields könnte ich bereits mit 13/10 EPDM Schlauch verwenden? In der FAQ steht, es gibt verschiedene Möglichkeiten ohne ausführlich zu konkretisieren. Ich habe bereits viel Geld in 13/10er Schlauch und Premium Fittings gesteckt, die Ultitube Combo habe ich schlicht und ergreifend zu spät entdeckt. Der Umbau auf 16/10 vermutlich erst nächsten Winter wenn ich genug Erfahrung gesammelt habe.
Mir würde eine reine Leckageüberwachung bereits ausreichen sowie das Feature des integrierten Dichtigkeittests trocken vor Innetriebnahme. Ist dies bereits mit 13/10 EPDM möglich?
SuperFlyRon
Sunday, January 4th 2026, 10:02pm
Ich hätte mal eine Frage zum Füllstand, behälter ist die Ultitube 200, habe das Kühlmittel 50mm unter der Oberkante des AgBs aufgefüllt, ist das so ok? Was ist mit der Membran, wenn es durch kondensierendes Kühlmittel auch Feuchtigkeit abbekommt? Ich benutze dp ultra in klar, falls es relevant ist.
This post has been edited 1 times, last edit by "SuperFlyRon" (Jan 4th 2026, 10:54pm)
Gaetan
Sunday, March 29th 2026, 12:18pm
ich vermute, dass das Problem durch Kondensation verursacht wird. Wenn sich das Wasser im Kreislauf erwärmt, steigt die Luftfeuchtigkeit im Reservoir. Wenn diese feuchte Luft mit kühleren Oberflächen im oberen Teil des Ausgleichsbehälters oder der Membran in Kontakt kommt, bilden sich kleine Wassertropfen.
Ich muss den LeakShield entfernen und die Membran etwa einmal pro Woche vorsichtig mit einem Mikrofasertuch trocknen, wenn ich das System so nutze, dass sich das Wasser aufheizt.
Jemand von Aquacomputer hat vorgeschlagen, die Schutzfolie auf der Membran zu lassen und es so auszuprobieren.
Eine andere Lösung, die ich in Betracht ziehe, ist das Wasservolumen zu reduzieren, damit mehr Platz an den Wänden des Ausgleichsbehälters bleibt, damit sich die Feuchtigkeit verteilen kann.
Allerdings wäre es besser, wenn jemand von Aquacomputer eine richtige Lösung für dieses Problem bereitstellen könnte.
Vielen Dank.
Mr. Krabs
Monday, March 30th 2026, 1:27pm
Du kannst natürlich auch mehr Radifläche verbauen. Dann wird das Wasser nicht so warm
firefox_i
Monday, March 30th 2026, 2:12pm
Hey,
also wenn sich auf der Membran Wassertöpfchen bilden find ich das seltsam.
Rein bauchgefühltechnisch liegt die Ratze deutlich drunter und wenn ich den CoPiloten mit den Infos füttere "45 Grad warmes Wasser in einer PC-Wasserkühlung bei 750mbar" spuckt mir der dann eine realistische Größenordnung von "<1g/Tag" aus.
Bilden sich da echt schon Tropfen?
S.
neuer Benutzername
Saturday, April 11th 2026, 1:17am
Ich habe keine 750 mbar 8o sondern nur zwischen 370 und 450 mbar. Je nachdem wie warm es im Gehäuse oder Raum ist, umso geringer der Unterdruck ;)
Leakshield reagiert extrem empfindlich auf Temperaturänderungen und
Luftdruck. Wenn ich das Fenster öffne, sehe ich das gleich beim
Leakshield :thumbsup:
45
Grad warmes Wasser habe ich höchstens im Sommer wenn es im Zimmer auch
Richtung 40 Grad geht. Im Schnitt sind es zwischen 30° und 40°.
und ja - da bilden sich schon Tropfen :)
neuer Benutzername has attached the following file:
