• 29.12.2025, 02:37
CoAff
Samstag, 4. August 2018, 14:07
Update:
You can reproduce the issue where service will not be installed with aquasuite 2018- 4 by deselecting desktop icon while executing aquasuite setup.
Oh wow, that's subtle error in some ways. I'm of the mind that I generally have a very cluttered desktop and even let software that I only use a few times a year position a squatter. I will go 'round and delete a few once it becomes ridiculous and have recently found a program called 'Fences' which really helps. For presentations which may include desktop sharing this software allows one to double click on a clear area to instantly hide the icons and then bring them back the same way.
Anyway, I had a situation where the service didn't start.... And digging through the interface brought me to the service section, whereupon clicking 'start service' started the service. It's been working well ever since.
edit: I just added the signature. That's so cool! Oh, and I'm using Win7 too.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »CoAff« (4. August 2018, 14:14)
dhdeang
multiple audio devices in the drop down menu for Audio and Video
Samstag, 4. August 2018, 17:37
I have way too many audio devices in the drop down menu. Is this normal?
»dhdeang« hat folgende Datei angehängt:
  • audio.jpg (213,81 kB - 307 mal heruntergeladen - zuletzt: 14. Dezember 2025, 13:13)
Dienstag, 7. August 2018, 01:11
Update:
When installing aquasuite and if you deselect desktop icon, which i always do, I don't like cluttering my desktop, that's when service is not installed, probably why you cannot reproduce it. I have several systems on my home network and even thou not all have aquacomputer product you can still install aquasuite and I have tested on all of them, every one of them ends up with the same results, so once again, this is aquasuite issue.
I can confirm the above as working for me.
I uninstalled the aquasuite, reinstalled allowing the desktop icon to be created, and the Windows Service was fully activated on startup.
Dundys
Dienstag, 7. August 2018, 04:34
Update:
Thanks for the confirmation :thumbup:
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »Dundys« (7. August 2018, 05:14)
RE: multiple audio devices in the drop down menu for Audio and Video
Mittwoch, 8. August 2018, 06:27
My list looks similar in length.
Twograves
Issues with Aquaero and update
Freitag, 10. August 2018, 09:07
So running into an issue with the new update. Fairly annoying, Since the update, Aquaero 6 xt will not respond or change "information pages". I can make changes via Time Sync or lets say shuffling through pages via remote. The issues lies for me when I"m in Aquasuite trying to adjust My Information pages won't take place I can remove or add a page nothing changes on the Aquaero. Any help will be much appricated.
novax1
Hardware Monitor service
Montag, 13. August 2018, 07:32
Hello everyone.
Hardware does not identify the name of the sensors.
the temperatures are not correct.
I leave photo
»novax1« hat folgendes Bild angehängt:
»novax1« hat folgende Datei angehängt:
  • error3.jpg (466,64 kB - 235 mal heruntergeladen - zuletzt: 13. Dezember 2025, 18:52)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »novax1« (13. August 2018, 07:36)
RE: Hardware Monitor service
Montag, 13. August 2018, 15:25
Hello everyone.
I leave photo
You may want to install the free HWiNFO to monitor your PC's hardware.
The aquasuite does it to a degree, but it is not it's strength.
That way you can also compare the values reported between both services.
ASservice vs. HWiNFO
novax1
Montag, 13. August 2018, 17:54
hello thank you for answering.
I apologize but I have to translate from Spanish to English if there is something written that is not understood.
With the previous aquasuite verifications afuncionado perfectly.
and compared to aida64 the information is not correct at some temperatures.
ino identifies the names of the sensors.
example I leave an image.
  • error01.jpg (351,97 kB - 211 mal heruntergeladen - zuletzt: 27. November 2025, 16:05)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »novax1« (13. August 2018, 17:56)
novax1
RE: RE: Hardware Monitor service
Montag, 13. August 2018, 17:56
Hello everyone.
I leave photo
  • error01.jpg (351,97 kB - 217 mal heruntergeladen - zuletzt: 15. Dezember 2025, 12:09)
novax1
blank text options
Dienstag, 21. August 2018, 06:24
in the 2018-5 check
the menu option is blank and it is not correctly appreciated.
I leave an image
Dienstag, 21. August 2018, 08:10
in the 2018-5 check
I can confirm this, we fix this soon.
When you hover with the mouse over the items it is readable - not good, but you can read the items.
novax1
Dienstag, 21. August 2018, 11:15
in the 2018-5 check
thanks for answering.
let's wait for the solution :thumbup:
Mittwoch, 22. August 2018, 10:40
2018-6 is online and fixes the problem with the context menu. It also includes a small improvement for multi monitor setups.
Mittwoch, 22. August 2018, 14:46
Is the "improvement for multi monitor setups" an efficiency thing internal to the program, or an enhancement I can use in placing objects on a 2nd monitor?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (22. August 2018, 14:48)
Mittwoch, 22. August 2018, 14:58
The hotplug handling when a desktop page is active is improved.
The problem with multi Monitor setups with different scales and resolutions is a bigger problem.
Some windows functions (WIN32 API) give as results only the unscales values/data.
When a window (desktop page) is displayed as a big window over more than one monitor. Windows use the most suitable dpi scale for this window.
smeroni68
Tack signal problem
Montag, 10. September 2018, 22:32
I have a question related to Tack signal starting.
I see all the times that I switch off the PC that at the first poweron, the mobo stop on POST with "CPU fan error... Press F1". I have connected the Aquaero 5 XT to the CPU fan plug with the cable (and it works perfectly).
On the other side, when I put the PC to suspend (Aquaero is in standby but switched on), after the wake there are no problems. If I connect a normal fan to the CPU plug, no problem at all, not from switch on and not from resume.
Is there any settings I miss to start the tack signal sooner, so the mobo will not stop the POST and avoid the error... is quite annoying.
Running Aquasuite latest version and firmware is updated.
Thanks for your help.
EDIT: My PC is with Ryzen 2700x and Asus Prime X370-Pro
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »smeroni68« (10. September 2018, 22:37)
GTXJackBauer
RE: Tack signal problem
Montag, 10. September 2018, 22:40
Are you using the RPM header behind your AQ5 to connect to your CPU fan header?
smeroni68
RE: RE: Tack signal problem
Montag, 10. September 2018, 23:02
Yes, and the signal is working fine.
Minor issue
Dienstag, 11. September 2018, 16:59
The tooltips for the "Analyze log data" page are white font on white background.
