• 26.11.2026, 01:35
Kruxarn
jeudi 16 janvier 2025, 20:35
With X.81, overview pages no longer load automatically at startup, and the same issue persists with X.82.
jeudi 16 janvier 2025, 21:39
The Overview page I have selected to load with Aquasuite is working fine in AQS X.81 and X.82. I have had this happen before, but it was back in 2021 and Aquasuite X.47. In my case, after a lot of troubleshooting, it just started working again and I never did figure out what caused the problem. I posted about it and at the end of the thread there was THIS POST from haaammit that may be of interest to you. Go to the Global Profiles section in the Playground and if its not already there, in the "Actions to be executed on profile load" add the overview page you want to load at startup to whatever Global Profile you have set to load at startup.
In the first attached screen snip, I have Global Profile 4 set to load on startup. Global Profile 4 loads Octo Profile 4, 2 x Farbwerk360's Profile 4, and my Default Overview Page.
Note - I also set my Default Overview Page to load automatically by clicking on its Gear icon and checking the box "Load page automatically". I am not sure what happens if one Overview Page has this box checked and a different Overview Page is added to the Default Global Profile. I have not tested this but if this condition exists in your system, maybe it is causing the problem.
Kruxarn
jeudi 16 janvier 2025, 21:44
Adding overview page to "Actions to be executed on profile load" solved my problem. Thanks!!
Ramazan
mercredi 5 février 2025, 15:00
Hi! Having trouble with AQS x.79, after mobo BIOS upgrage sensor data for GPU from Aqua Computer Service are invalid. Disable and enable hardware monitor didn't help. Any suggestions?
Ramazan a envoyé l’image suivante :
Mörökölli
vendredi 7 février 2025, 19:48
Any ETA for support for NVidia 50x0? Upgrading GPU and realizing that it's not... there.. makes one realize just how nice Aquasuite is and how painful it is when it's not. ;(
samedi 8 février 2025, 01:40
I just disable all hardware monitoring in Aquasuite and import sensor data from HWINFO via its shared memory feature. HWINFO reports a lot more sensor data than Aquasuite and is updated far more often to keep up with new hardware. In 2024 HWINFO was updated 53 times. Aquasuite was updated 3 times. I am not knocking Aquasuite. It is absolutely the best software out there for cooling loop component control. HWINFO is the best software out there for sensor polling. The primary function of Aquasuite is to control Aquacomputer cooling loop components. The primary function of HWINFO is to poll hardware sensors. The shared memory feature allows sensor data from HWINFO to be imported into Aquasuite very easily. Yes you have to pay for a license to avoid the 12-hour shared memory limit in HWINFO. Its well worth the cost of the license IMO. By using each program for what its best at doing, I get the best of both, and I don't have to wait for Aquacomputer to get around to adding support for new CPUs, GPUs, and Chipsets.
Mörökölli
samedi 8 février 2025, 08:23
Yes, I know about HWInfo, but since I don't need it, I don't want it either running or to pay the license fee for it, as meager as it is. The primary function of Aquasuite may be to control loop components for you, but as the vast majority of my loop components don't need controlling, the primary function for me is monitoring the loop - and the components on the side. And thus the question about the ETA, not about a workaround although the kind thought is appreciated.
Oh. Never Mind. It seems Something Was Amiss that got fixed by a boot at some point. The 5090 is now visible. 8)
dimanche 9 février 2025, 03:04
Yes, I know about HWInfo, but since I don't need it, I don't want it either running or to pay the license fee for it, as meager as it is. The primary function of Aquasuite may be to control loop components for you, but as the vast majority of my loop components don't need controlling, the primary function for me is monitoring the loop - and the components on the side. And thus the question about the ETA, is not about a workaround although the kind thought is appreciated.
Fair points, and glad to hear the 5090 sensor polling is now working. Also, congrats on getting a 5090!!
WaterBoy61
dimanche 9 février 2025, 19:56
I don`t think X.82 is working properly. All the assigned names to my fans and sensors on the Overview page and Fan page do not stay. They keep reverting back to the default settings, like Sensor 1,2,3 and Soft Sensor 1,2,3, etc.
gr3y5had0w
mardi 11 février 2025, 11:21
I'm facing a similar issue. After each start or restart all the sensors are not working. I have to restart the aqua suite service every time (restart with admin privileges, stop service, start service) to get any sensor. MSI X870 Tomahawk (latest BIOS), Ryzen 7 9800X3D (latest Chipset driver).
Ce message a été modifié 1 fois. Dernière modification effectuée par "gr3y5had0w" (11 février 2025, 11:37)
SgtSixpack
samedi 19 avril 2025, 14:19
Just realised: I'm not using any of the shared sensor data; so I can disable the hardware monitoring in aquasuite so I'm not using the winring0 driver.
dimanche 20 avril 2025, 02:53
If by shared sensor data, you mean data provided by HWINFO via its shared memory feature, if you are not using that, and you disable all of Aquasuite’s hardware polling, you will not have any sensor data available in Aquasuite. If you are importing sensor data from HWINFO (which does not use Winring0), there is no reason to leave any Hardware Monitoring active in Aquasuite because HWINFO reports everything that Aquasuite reports and more. I checked each of AquaSuite’s 7 hardware monitoring categories, and they all use Winring0_1_2_0. It may not be an issue, at least for now. Check THIS POST for details. Microsoft may have decided to temporarily allow Winring0 to give software developers time to develop their own signed drivers, but I think they will eventually flag it again because of security concerns due to it being a Kernel level driver. I provided links to several articles and a Gamers Nexus video about the history of and problem with Winring0 in THIS POST.
Marucins
dimanche 18 mai 2025, 12:10
Does the program monitor the RTX 5090 GPU?
I don't have the card listed. Version X.82
lundi 19 mai 2025, 11:38
Yes, that works.
Marucins
mardi 20 mai 2025, 22:15
Yes, that works.
[attach]11086[/attach]
Thanks
You are right.
It appeared after updating to the latest drivers - because I did nothing else on the system.
And will you improve the correct temperature reading for memory?
HWINFO - reads correctly.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Marucins" (20 mai 2025, 22:21)
mercredi 21 mai 2025, 09:21
We just read out the data that is provided by Nvidias official driver API. It is not the first time that values go away and reappear in later version.
Right now, we can't do anything about it.
HWiNFO very likely fetches the data in a different way.
Krutors
New Feature Idea - Fan control via RPM instead of PWM duty-cycle
mercredi 28 mai 2025, 20:58
Hello.
First, I apologize if it's not the right place to post this, feel free to move it where my post belong if it's the case..
I wonder if it would be possible to add a feature to Aquasuite to allo users to control fan groups via RPM values, instead of raw controller PWM signaling (with the help of some pre-calibration, like what FanControl is doing)
I'm quite new to Aquasuite, (I bought a Quadro a few weeks ago), so if it's already possible to do so in any way, I also apologize.
X.83 Update
mercredi 3 septembre 2025, 01:25
It’s nice to see an Aquasuite update after almost 8 months. It would be helpful to receive a bit more detail about the changes made. The release notes list 5 Bug Fixes (one with a Leakshield firmware update) and 3 Updates. Some of them are self-explanatory, but others are not.
  • Update: Playground Connections – What does this mean? Are there any new features?
  • Bug Fix: RGBpx settings – What settings? What bug?
  • Bug Fix: Leakshield Alarm Actions – What has changed about how Leakshield Alarm functions?
Any additional info is appreciated.
mercredi 3 septembre 2025, 07:20
Many changes have been made, but these are not obvious to the user. This is the case with every update and will not be listed in detail.
willh
mercredi 3 septembre 2025, 11:02
As a user who has purchased several licenses for Aquasuite and have multiple active licenses, I'd like know a little more!
Perhaps my Leakshield won't be quite so annoying anymore?
Discussions similaires
