• 25.08.2026, 13:14
Remayz
Donnerstag, 26. Februar 2026, 09:41
I have started having a lot of issues since X86 that looked to be the service not starting but seem to be the application itself in the end.
At boot, the dashboard will only show hardware sensors. All the virtual and software ones won't be active. Usually that's when the service is not running, but when i look in windows services, it is. If i wait long enough, aquasuite will popup the message saying the service is not active etc..
If i just close aquasuite and restart the app, it will pick up the service and display everything.
I know the service works because during boot the fans run at their fallback speed, a bit faster than usual, and after i log into windows, they slow down and get controlled. So there is something here that seem to make AS not communicate with it.
Remayz
Freitag, 27. Februar 2026, 17:18
Well, first boot with X87 and it seems solved :D
Klirng
Samstag, 28. Februar 2026, 17:06
The antivirus recognized the update as a PDM:Trojan.Win32.Generic ?(
Remayz
Samstag, 28. Februar 2026, 18:32
that's still the winring0 hardware monitoring. you have to disable all hardware monitoring within aquasuite options. I have it all disabled and windows defender doesn't complain
hvckmvn
new driver
Dienstag, 3. März 2026, 04:06
updates on ms driver status? have bought 2 quadros, 2 farbwerk360, and purchased updates for my newer quadro hoping these issues get worked out... i cannot continue to buy into updates supporting aqua when the updates arent containing the fix i need
Changelog
aquasuite X.88 (2-MAR-2026)
  • Bugfix: aquasuite tray icon, profile switch
AMPINEL Firmware 1002:
  • New: Distinction between 300W, 450W and 600W input power cables
willh
Dienstag, 3. März 2026, 16:19
Are we any closer to shipping a non-vulnerable version of Aquasuite?
The suggestion to not use basic functionality in software I am paying for, as a workaround, is not good enough.
I get this every time I start my PC...
Hopper64
Mittwoch, 18. März 2026, 18:53
Just installed X.89 and I am not seeing any antivirus alerts so far.
Donnerstag, 19. März 2026, 08:18
Note: The X89 is available as an insider build.
ksenchy
Dienstag, 7. April 2026, 23:43
Are we planning to move to PawnIO instead of WinRing0 for hardware monitoring?
Mittwoch, 8. April 2026, 07:15
The Insider Builds use a NEW in-house developed driver, not PawnIO or Ring0.
ksenchy
Mittwoch, 8. April 2026, 09:11
That's even better. I still didn't receive my AMPINEL so I didn't try yet, but can you select insider build from the setup posted on the forum?
Mittwoch, 8. April 2026, 16:32
You can enable an option to show insider versions in the setup and also in the update tab of the aquasuite itself. But since the current insider version will become the regular release version in a day or two anyway, you don't need to worry about this anymore ;)
ksenchy
Mittwoch, 8. April 2026, 17:20
Wonderful. Just in time as my AMPINEL has been shipped today. I can wait a couple of days :thumbsup:
Thanks for the support guys
sknowledge
linux!
Samstag, 11. April 2026, 10:56
As the move from Win to linux is well underway, I would love to have this wonderful piece of software supported on linux, as a flatpak.
Thank you!
Samstag, 11. April 2026, 12:06
What kind of shift are you talking about? Linux 3.5%, Windows > 70%.
On Steam, the Linux share is 2.7%, including the Steam Deck.
We don't have any plans to experiment with Linux in the near future.
SgtSixpack
Montag, 13. April 2026, 16:19
I updated to x.91 and checked memory in hardware monitor. I don't see RAM temperatures just RAM usage which is a little disappointing. My RAM can hit 47'c even with a 140mm noctua fan at 65%.
Freitag, 5. Juni 2026, 11:16
From version X95 (insider) onwards, the Net10 Runtime is required and 32-bit support is no longer available.
Run desktop apps, .NET Desktop Runtime
.NET 10 installer: https://dotnet.microsoft.com/en-us/downl…s-x64-installer
https://dotnet.microsoft.com/en-us/downl…et/10.0/runtime
Karishin
Mittwoch, 19. August 2026, 23:09
For some reason the aquasuite service started losing the ability to monitor my GPU temp. It initially works fine but at some point it loses all ability to see the GPU sensors and starts blasting fans at full RPM.
UPDATE:
It seems to have been something to do with cura silcer, whenever i'd eject the USB it would cause aquasuite to lose all motherboard sensors. Stopping and restarting the service fixes it.
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »Karishin« (22. August 2026, 16:08)
