• 30.11.2026, 22:02
Wednesday, October 4th 2023, 7:24am
yes, that would be great
Currently, the aquasuite does not support this feature.
We have made a note of this. However, the feature is not a priority for us. We can't say if or when we will implement it.
mditsch
Wednesday, October 4th 2023, 7:33am
:thumbsup: :thumbsup:
Teknophage
Unable to edit page with lots of meters.
Saturday, October 28th 2023, 6:58am
Hi!
I've run into a problem with the latest version. If I have a lot of meters on a page, it will display, but I cannot edit or view it within Aquasuite. The window will freeze and I have to terminate the application. When I relaunch, the page will display on the desktop. If I attempt to edit or view it again inside Aquasuite, the application hangs again.
Pages with far fewer meters work just fine. Is there a limit on the number of meters or a recommended maximum number? I can recreate this situation.
I also noted that an older version of my desktop page works. When I add one additional meter, it crashes Aquasuite. If I import the old version, it works normally. This did not happen with the previous version. I'm going to attempt reinstalling the previous version if possible. ?(
Update: I tested again by removing the additional meter I added, and the page no longer crashes. Adding the meter back and it crashes. There's definitely something there as it doesn't matter which meter I add, I hit a ceiling. Going to split the meters up across other pages like a sane person. :D
Thanks!
This post has been edited 1 times, last edit by "Teknophage" (Oct 28th 2023, 7:26am)
Saturday, October 28th 2023, 7:42am
Macke Screenshots and describe exactly what you are doing to reproduce the problem in a new Topic.
Hopper64
Thursday, November 2nd 2023, 3:53am
Just a heads up. I just installed windows 11 23h2 and Aquasuite would not load without a significant delay. I found a new version of Microsoft desktop runtime version 7.0.13 and installed over the prior version xxxx.12 I think. Problem solved.
anon1
Wednesday, November 8th 2023, 8:44am
Anyone have software sensors disconnecting? For me when I restart my computer/aquasuite autostart, the soft sensors will return blank readings after a few seconds. If I stop and restart the aqua computer service, and close/restart aquasuite the problem resolved. I tried setting longer autostart delay for the aqua service and aquasuite, but doesn't helps.
Using Aquasuite X.76, Windows 10 IoT 21H2.
Wednesday, November 8th 2023, 9:56am
Check your Windows error logs. You may need to update your system to the latest version.
Deactivate the hardware monitoring.
What exactly do you mean by restart? Power Off -> start, Standby -> start, Resume -> start?
anon1
Thursday, November 9th 2023, 4:17am
Thanks, yes indeed there were errors in event viewer.
Aquacomputer service event ID 0
Service cannot be started. The service process could not connect to the service controller.
2 instances of RestartManger errors
Application 'C:\Program Files\aquasuite\AquaComputerServiceHelper.exe' cannot be restarted - Application SID does not match Conductor SID..
Application 'C:\Program Files\aquasuite\aquasuite.exe' cannot be restarted - Application SID does not match Conductor SID..
Hardware monitors were off.
Errors from power off > start.
Is there any windows service dependencies that I have to check? i have disable a few default windows services.
Thursday, November 9th 2023, 7:12am
bad idea, revert this and use the default settings.
We can't help you if your Windows configuration is broken.
Hopper64
Wednesday, November 15th 2023, 12:30am
Just saw a new version of Microsoft .net runtime version 8.0.0 but it does not work with aquasuite. You still have to use .net 7.0.xxx. Will this be updated to include version 8.0.0?
Hopper64
Sunday, December 31st 2023, 3:26pm
I have the latest version of .net framework 7x installed but I keep getting a significant delay in aquasuite coming up after clicking on the icon. It sometimes sits there for 15 seconds before the application starts. Anyone know what’s wrong?
jonsky7
Monday, January 1st 2024, 1:00am
Hello, Ive just installed the update for aquasuite x.76 24-DEC-23.
All of my virtual sensors have stopped working. It seems the virtual software sensors are not importing the data inputs I'm selecting.
I can see the values in the "select data source" menu, but they are not being imported to the virtual sensors page.
Any ideas?
Thank you
Happy New Year
Remayz
Monday, January 1st 2024, 4:35pm
are those sensors using HWinfo data by any chance?
it happens sometimes that you have to reselect the sensors after an update of aquasuite or HWinfo.
jonsky7
Monday, January 1st 2024, 8:10pm
I've just noticed that nothing is updating, no matter the source, whether that be HWinfo, direct from the octo, or anything else for that matter. :(
jonsky7
Thursday, January 4th 2024, 9:15pm
Seems the aqua suite service starts up with windows and sends/gets an initial value, then just stops updating. If I stop the service and start it again, aquasuite starts to work fine again.
PC
Windows 11 Pro
12900k
64GB 3200Mhz DDR4
Asus Tuf gaming Z690
4090FE
Samsung 990 pro x2
Samsung 980 pro x2
Remayz
Thursday, January 4th 2024, 11:12pm
maybe try to increase the service start delay in Aquasuite settings ?
Thursday, January 4th 2024, 11:32pm
Are you running Microsoft .NET Framework V7.0.x? This has been required since AQS X.67.
Sarioah
Friday, January 5th 2024, 12:14am
Would it be possible to implement a "schedule" for the D5 Next OLED screen?
I have my PC's RGB lights turn themselves off automatically in the evening, when the room is darker. It would be fantastic if I could program the D5 to automatically dim (or better yet, turn off) the display within a specified time window
Friday, January 5th 2024, 1:28am
I believe this can be done using Global Profiles "Time switch" function
Sarioah
Sunday, January 7th 2024, 3:36am
Ah thank you, yeah that does what I need
