You are not logged in.
anub1s21
anub1s21
This post has been edited 4 times, last edit by "anub1s21" (Oct 27th 2026, 11:45am)
anub1s21
This post has been edited 1 times, last edit by "anub1s21" (Oct 28th 2026, 5:52am)
Perform a clean install of AquaSuite.....seriously can i downgrade the firmware i much preferred the behaviour where from the moment it started it followed my settings.
anub1s21
Reset your device to facory defaults.
If the problem persists, please start a new thread on the forum detailing the specific issue, including screenshots and a description of the error.
This is not a fault with Aqausuite.
according to the notes by the firmware the curve controller startup the thing i am having issue's with is litterally the only thing mentioned that got changed, so if i seem nettled it's because i am because most of my messages don't seem to be read correctly.
Quoted
Nothing you’ve described has been changed.
Reset the device to its factory settings using Aquasuite and reconfigure it.
This post has been edited 3 times, last edit by "anub1s21" (Oct 29th 2026, 5:10am)
Rodders_UK
This post has been edited 1 times, last edit by "Rodders_UK" (Oct 31st 2026, 4:34pm)
