• 26.08.2026, 03:10
_AK_
mardi 6 août 2019, 06:03
When you try to download Aquasuite X4 and install after reinstalling Windows 10, an error occurs.
The server was unavailable last night.
I ask you to drop me the installer, I can not configure my system because of this!
mditsch
mardi 6 août 2019, 08:16
you can download it here:
https://aquacomputer.com/software.html
_AK_
mardi 6 août 2019, 09:18
This error occurs after downloading the installer using your link. Otherwise, where would I get the print screen, which is in the post above ...
Dundys
mardi 6 août 2019, 16:58
Try changing Time Zones or check your current time. For the first time ever I had this happening also and nothing would work until I started changing Time Zones, try it, it might work
bojer
vendredi 9 août 2019, 21:28
D5 Next showing as some USB device. Can you fix this? Thanks.
bojer a envoyé l’image suivante :
jeudi 14 novembre 2019, 14:49
Version X7 (insider) with many bugfixes is online.
Version X8 is online and fix some issues from X7.
vendredi 15 novembre 2019, 13:49
mhmm, my version X7 (insider) does not show X8 update as available (insider is checked). Guess I will manually download it.
Still hoping you are working on implementing push notification to the Windows Notification service for those of us who minimize on startup.
vendredi 15 novembre 2019, 14:29
You can also use the dowloader to install the aquasuite.
vendredi 15 novembre 2019, 15:12
Downloader?
I went to https://aquacomputer.de/software.html to download the update.
My version X7 was not aware of an update, so no downloading option was given in the aquasuite.
Am wondering If I was the only instance, or if others also did not have their X7 version detect X8 availability?
Megalamaniac
vendredi 15 novembre 2019, 22:33
My X7 didn't notify me of X8 until I rebooted my PC. It showed X8 available then
Downloader?
Zagdima
mardi 19 novembre 2019, 21:46
Hello. I have farbwerk nano. And on version X6-x7 the audio analyzer works fine. But on X8 they any sound exist in system it shows only 2 small bars for left and right channels. See picture 1. On previous version was a lot of bars under the main sound selector menu. See picture 2. So for now my spectrum analyzer doesnt work. What can be a problem?
mditsch
mercredi 20 novembre 2019, 19:01
[attach]7071[/attach]
[attach]7072[/attach]
Are these two services running?
softlion
mercredi 20 novembre 2019, 19:12
Aquasuite X8:
it've just installed it.
After install the CPU of the AquaComputerService.exe process is 50% and stays at 50%.
X6 worked perfectly.
Plz bug fix asap.
UPDATE
I found a way to fix the issue:
- quit acquasuite
- open acquasuite in admin mode (run as administrator)
- stop the acquasuite service using acquasuite/service/stop button
- start the acquasuite service using acquasuite/service/start button
It won't take 50% CPU anymore
Ce message a été modifié 1 fois. Dernière modification effectuée par "softlion" (20 novembre 2019, 19:31)
Zagdima
lundi 25 novembre 2019, 20:07
Yes. Now i'm on X6 and everything works but not on x8
Hopper64
mercredi 4 décembre 2019, 14:15
Tried Installing X.9 without success. It simply comes back to version X.8. Uninstalled the whole software suite, rebooted, downloaded the installer to X.4 and updated which brought me to X.8 even though X.9 is available.
mercredi 4 décembre 2019, 14:52
Try ist now again.
Hopper64
mercredi 4 décembre 2019, 15:06
Try ist now again.
Yes. That fixed it. Thanks!!
hockeythug
lundi 23 décembre 2019, 23:42
Nm. Fixed
Ce message a été modifié 1 fois. Dernière modification effectuée par "hockeythug" (23 décembre 2019, 23:50)
MStauning
No HWInfo support?
vendredi 10 janvier 2020, 08:15
Well just updated my license, and now Aquasuite cant see any sensors from _HWInfo.
Its X.11 relase date 20-12-2019
MStauning a envoyé le fichier suivant :
  • NOHWInfo.jpg (32,43 kB - téléchargé 2 782 fois - Dernier téléchargement : Hier, 23:05)
vendredi 10 janvier 2020, 08:28
Restart your computer afer the Update.
Discussions similaires
