• 26.03.2026, 12:48
aquaman2030
Playground Inputs HELP!
Montag, 8. Januar 2024, 01:45
Hello,
I came across this document: New: aquasuite X.45 - Need input! / Controls on the desktop or in the system tray / New profile system
and wanted to play around with Inputs to control brightness of aRGB and another knob to control Fans RPM, for example. However, I could not get the Inputs to associate with the devices (or appropriate controllers). The document is for X.45 and I'm using X.77. I understand that the UI has changed. I can see the knobs and sliders, etc but when I clicked on the Fans or RGBx of my D5 NEXT or highflow NEXT, I couldn't find a way to associate these inputs with those devices/controllers.
Please let me know if there's a more current document or what I did wrong. I really love my dashboard so far and would like to add a few inputs so that I could adjust fan speed and LED brightness.
Thanks in advance!
Montag, 8. Januar 2024, 04:12
@aquaman2030
Hope THIS helps
aquaman2030
Montag, 8. Januar 2024, 04:34
@aquaman2030
Hope THIS helps
Thank you very much for taking the time to make the walk-through video sir! I seems to me that I need an OCTO device?
I don't see the gear icon at the bottom of my D5 NEXT view to click on. I also do not have the gear icon under RGBx for neither D5 NEXT nor highflow NEXT.
I wanted to attach a few screenshots but hit a max length limit of 10,000 characters.
Montag, 8. Januar 2024, 05:03
@aquaman2030
Oops, my bad, I did not consider a build without an OCTO. It looks like Inputs are not integrated into the D5 NEXT or the High Flow NEXT... sorry. :(
aquaman2030
Montag, 8. Januar 2024, 05:43
@aquaman2030
No worries, InfoSeeker. You've helped me confirm that I haven't become senile. Was spending the last two days trying to configure Inputs to control the devices.
PvF
Montag, 8. Januar 2024, 06:01
For devices other than the Quadro or Octo it is somewhat more complicated to use "inputs".
For example, I only have the option of setting the speed of the D5 Next via virt. software sensors.
- Add a new input (pump power [%])
- Convert the % into a 1:1 temperature using virt. software sensors
- integrate this virt. software sensor into the d5 Next via one free "soft. sensor"
- Use this temperature as a linear input for the speed of the D5 Next
For other things such as RGB, this should also work in the same or similar way if you can set a temperature to influence it
e.g. for the fan control, instead of using the 1:1 translation in the 2. step of converting the input [%] into a temperature, you can take the CPU temperature as the actual control variable and add the value via "inputs" as an offset.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »PvF« (8. Januar 2024, 06:41)
aquaman2030
Montag, 8. Januar 2024, 22:00
[attach]10618[/attach]
[attach]10619[/attach]
[attach]10621[/attach]
[attach]10620[/attach]
Thank you PvF, I was able to 'simulate' the inputs following your steps. Is there a way to submit a request to Aquacomputer to enhance this functionality?
For RGBx brightness, it's also driven by "Data Source" and therefore limited to the effect that I use. I remember seeing someone was able to configure a slider under "Brightness" but not sure if it was also limited the what effect that person was using.
»aquaman2030« hat folgende Bilder angehängt:
Hopper64
Samstag, 27. Januar 2024, 05:59
I am having issues losing data in aquasuite. Everything is updated. Latest version. Suggestions?? Thanks
https://i.imgur.com/cc4FJHx.png
Samstag, 27. Januar 2024, 16:20
Need a data trail to determine what is up:
  • are you pulling the temps with aquasuite's 'Hardware Monitor' or HWiNFO?
  • do you see the temps in 'Data quick view'?
  • what is the one labeled 'temperature' & what is the source?
Hopper64
Samstag, 27. Januar 2024, 17:58
I set it up to provide the data from the aquasuite service itself, not HWinfo. I am not seeing the temps in the data quick view. The one labelled temperature is the SSD temp. Looks like the aquasuite service is not polling those values. I am going to reenable them and reboot. Thanks.
Hopper64
Samstag, 27. Januar 2024, 18:07
That was it. Don't know why but the hardware monitor under the aquasuite service was disabled. I simply reenabled those and the data is there. Have no idea why the hardware monitor was disabled. ??? Appreciate your help.
https://i.imgur.com/gxYi7za.png
Hopper64
Samstag, 27. Januar 2024, 18:13
strumf666
Sonntag, 28. Januar 2024, 17:31
I am still missing all the temperature of my graphics card (6900xt) after the last update. Enabling/disabling gprahics card under hardware monitoring doesn't make a difference.
»strumf666« hat folgende Datei angehängt:
  • aquasuite.jpg (80,67 kB - 1 192 mal heruntergeladen - zuletzt: 21. März 2026, 22:00)
PvF
Montag, 29. Januar 2024, 04:47
User "sBronco" had the same problem with his RX 6900 XT -> thread in german
He was able to solve the problem by reinstalling aqua suite
Montag, 29. Januar 2024, 08:52
If you stop the service once from the aquasuite after installing the new (GPU) drivers and then restart it, it also works.
This must be done directly from the aquasuite.
strumf666
Montag, 29. Januar 2024, 10:55
[attach]10689[/attach]
Thanks, stopping and restarting the service worked.
Dundys
Mittwoch, 14. Februar 2024, 16:24
So far X.78 works smooth.
rbato
Mittwoch, 14. Februar 2024, 20:46
Hello,
Hmm, sadly after updating to X.78 looks like Aquasuite is unable to check activation.
Yes, I updated without reading the Balloon Tip on the update. (I remember that it mentionned activation or key).
By the way, I thought that the install already installed .NET Framework 8 but after rebooting the pc it looks like not. So It's now installed.
Clicking Activate doesn't do anything.
Trying to re-register the key doesn't work, because it's already activated.
Aquasuite Service is running.
Changelog doesn't mention anything about this issue.
What did I miss?
Thanks,
Ok, well, I tried to reinstall Aquasuite :
https://imgur.com/a/Q92Z3Ny
?( Does it means that spending money after install is mandatory?
Are you serously starting a pay per install scheme?
»rbato« hat folgendes Bild angehängt:
»rbato« hat folgende Datei angehängt:
  • updates.jpg (118,41 kB - 1 321 mal heruntergeladen - zuletzt: Gestern, 07:52)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »rbato« (14. Februar 2024, 20:54)
Dundys
Donnerstag, 15. Februar 2024, 01:45
It looks like your subscription is expired in January so you cannot update to X.78, but you should be able to reinstall to the latest prior to your expiration date which is X.77
Donnerstag, 15. Februar 2024, 06:16
