• 30.11.2026, 17:57
sultan.of.swing
mercredi 11 mars 2020, 17:15
For me, the aquasuite saves the "Desktop" mode status on exiting aquasuite.
If the Monitor icon is selected (orange) on exiting aquasuite, then that is the state on restart.
Conversely, if the Monitor icon is deselected (white) on exiting aquasuite, then that is the state on restart.
Don’t think the issue is being fully understood.
Dundys
mercredi 11 mars 2020, 20:51
Does anyone know this broken aquasuite X.13 icon in start menu after either update or clean install, no rebuild of db or at least other fixes I'm aware other than to install aquasuite twice fixes it.
sultan.of.swing
mardi 17 mars 2020, 04:02
Still dealing with this issue of Aquasuite starting in "desktop mode"
mardi 17 mars 2020, 07:20
?? tested and everything is working. You have to mark the page for loading automatically (settings of each page) the close the aquasuite.
sultan.of.swing
mercredi 18 mars 2020, 03:27
The page is set to load automatically, which it does but everytime aquasuite opens up that page that I have set to open automatically gets put in desktop mode. This is something new that started with X13 as previous versions did not do this.
I decided to do a fresh install of X13 and the issue is gone so something from going from X12 to X13 caused it.
Ce message a été modifié 1 fois. Dernière modification effectuée par "sultan.of.swing" (18 mars 2020, 04:03)
Hopper64
mardi 31 mars 2020, 03:00
With version X.14, is that available for download?
mardi 31 mars 2020, 05:38
I appear to be missing some information on the X.14 aquasuite > Updates tab: updates_dates.jpg
Edit: and YAY for notifications :D
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (31 mars 2020, 05:40)
mardi 31 mars 2020, 07:35
with the next system startup or update check all informations are available
mardi 31 mars 2020, 13:43
I did restart the system last night after installation, but I guess an update check was not performed at that time.
This morning, after system start and update check, the dates & times are populated.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (31 mars 2020, 13:44)
fomenegra44
no fan speed info
mercredi 1 avril 2020, 15:03
Hi everyone. After a lot of newer versions of the software i'm not getting the speed fan info. Any solutions. thanks in advance.
Ce message a été modifié 1 fois. Dernière modification effectuée par "fomenegra44" (1 avril 2020, 15:05)
cptninc
jeudi 2 avril 2020, 03:57
I love the look of the new default pages! One thing that would be nice with pages: it would be nice if elements could be grouped so that an entire gauge can be moved as one unit.
Also, a feature request: I'd love it if Aquasuite Web were updated so that my webpage could match the overview page in Aquasuite.
ManniX
jeudi 2 avril 2020, 10:21
I found the aquasuite service hogging the CPU, one core, at 100%.
When I opened the aquasuite program the UI was crawling slow.
Then it asked me to update from X13 to X14.
I guess the update service needs some fixing; X13 was a fresh and first time install.
Once updated everything went back to normal.
Ce message a été modifié 1 fois. Dernière modification effectuée par "ManniX" (2 avril 2020, 12:55)
paskowitz
jeudi 2 avril 2020, 20:12
Any updates on fixing time based automatic profile switching going out of sync. For me, I will set a profile 1 and a profile 2. 2 is the same as 1 except for the RGB being off. I set the profile 1 switching time at 7am and the profile 2 switch time at 10pm. So, between 10pm and 7am, profile 2 should be active. However, what ends up happening is the profiles don't switch, then out of sync, switch. Basically, it seems like the timing gets thrown off. I would assume the Aquasuite would be reading the internal windows clock so I don't get why this would happen. Also, Aquasuite program and service are always running. Also set to run as admin. ATM I just use hotkeys to switch off the RGB at night, but it is still annoying not being able to use this (nice in theory) feature.
ManniX
lundi 6 avril 2020, 15:45
I've just updated to X.15 and it went smooth.
No CPU hogging issue like last X.14 upgrade. :thumbsup:
GTXJackBauer
lundi 6 avril 2020, 17:03
That's good news. I'm currently seeing only a X.14 notification.
Hopper64
lundi 6 avril 2020, 17:48
Updated to X.15 but it says X.15 available for update.
Hopper64 a envoyé l’image suivante :
lundi 6 avril 2020, 17:52
restart your pc ....
Hopper64
lundi 6 avril 2020, 17:54
Yes. Disregard. Thanks!!
lundi 6 avril 2020, 20:53
X.15 was also a bit of an unusual update for me.
I selected the retain settings option when asked during the install.
Upon restarting X.15, after the installation, I had this when I open the aquasuite: after_restart.jpg
rebooting the system corrected this issue, though I have never had to reboot before.
Also in the start menu I have two aquasuite folders: start_menu.jpg
The reboot did not correct this issue.
I suspect an uninstall and reinstall may fix the issue.
And I did not notice a Windows Notification Flag when X.14 started this morning.
The aquasuite does not list in the Notification setup screen: notification_main.jpg
Edit: with X.15 the aquasuite DOES list in the notification setup screen now.
Edit: uninstall/reinstall did correct the double listing in the Start menu.
Ce message a été modifié 3 fois. Dernière modification effectuée par "InfoSeeker" (6 avril 2020, 21:13)
mardi 7 avril 2020, 10:59
The X16 release with a few fixes is online.
Discussions similaires
