Du bist nicht angemeldet.
Jesaul
Evil-I
updated my Aquasuite and it's saying no registered device as update service ran out 31/5/2019 but cant find a version of the software
AnGelo
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AnGelo« (27. Juni 2019, 08:48)
We had to remove the M.2 support because it caused problems and did not run stable.both of my M.2 drives (Samsung 960PRO and Intel 660P) are disappeared from the Hardware Monitoring service
After a normal update? After a normal install you see a dialog to keep you data.
This next X3 update wrecked all my settings.......
Cenedd
All working as expected here. If you are able to fix M.2 support that would be appreciated as it would simplify my setup. Currently I have a pair of Samsung 950 Pro's in RAID 0 and to get temperature off them, I have a temperature probe taped to the bottom of each. If it can be done in software, that's two cables that don't need to contribute to the spaghetti!
If you're looking for additional features, would it be possible to export data to SNMP? The reason I ask is that I also run monitoring using Microtik's The Dude. If Aquasuite would export to SNMP, I could let it graph the enclosure temperatures over the year....which gets important around this time of year!
Many thanks,
Gareth
Cenedd
If you install HWiNFO (free) you should be able to pick up those values under aquasuite services > HWiNFO.
It is a more comprehensive system analysis tool than the aquasuite built-in version, but works the same way & is transparent to the user.
