• 06.10.2026, 22:10
X13 Localization error?
Wednesday, March 4th 2020, 6:59pm
In playing with the new "Gauge" element in X13, it appears there may be a localization error?
Under the 'Text' tab, in the 'Show unit' section, the 'Text position' description shows 'Virtual Vertical position of the text'.
But the value actually appears to affect the horizontal relationship between the 'value' and the 'unit' displayed.
Edit: spellcheck bit me.
This post has been edited 1 times, last edit by "InfoSeeker" (Mar 4th 2020, 9:05pm)
Maki911
Wednesday, March 4th 2020, 10:44pm
My aquasuite got updated today and I, changed the theme to "Dark" and this is what I get when I open aquasuite. :( Can't use itACupdate.jpg
Maki911
Wednesday, March 4th 2020, 11:37pm
Nevermind my post above, the inability to use aquasuite came from 2k malwares my PC had (after clean up everything was running smoothly). - Admin please delete my two posts here, it's just cluttering the thread.
Thursday, March 5th 2020, 7:21am
My aquasuite got updated today and I, changed the theme to "Dark" and this is what I get when I open aquasuite. :( Can't use it[attach]7266[/attach]
you have to click to the left sidebar to open the navigation.
WelshRambler
Friday, March 6th 2020, 10:32am
Since 1.2 I've not been able to control the RGBs on my RGBpx LED ring for aqualis 450/880, 15 addressable LEDs which is plugged into my D5 Next.
It shows on the RGBpx page, but with no output.
Same with v1.3.
Friday, March 6th 2020, 12:57pm
Switch the Output mode in system tab from aquabus to rgbpx
RaNDoM
RE: OCTO doesn't work with X.12
Friday, March 6th 2020, 1:01pm
After update to X.12 version OCTO fan controller doesn`t work with it. Writes that the firmware is outdated, but the update is not performed.
this looks line an usb issue, connect the octo without any usb hub or other devices to your mainboard and try the update again. Power off your computer before and after the update.
Close all 3rd party Software like aida, hwinfo, afterburner, rtss....
I disabled all USB devices . Left only the Octo and mouse connected . Disconnected the fans from the Octo. The firmware was updated under X. 13. Everything is working fine now. Thanks for the help.
WelshRambler
Friday, March 6th 2020, 6:49pm
Awesome!
Cheers!
Zagdima
RGBpx
Friday, March 6th 2020, 10:21pm
Can you tell me. Why RGBpx has only 20 led controller lines for leds? I have farbwerk nano. Is it limit for my device? If i buy farbwerk 360 will i get more lines for rgbpx(not for separate rgb out put)? If i use multiassign i have more lines but it just a copy of previous controller and if you change it, it changes previous block from which i copy it. Is it possible what in future will be more cotrollers? f.e.F on nano i have 90 leds support so will be it possible to have 90 lines for each led (90 led contollers)?
[img]https://forum.aquacomputer.de/index.php?page=Attachment&attachmentID=7271&h=453a1dfc5f7f6f55d5edec59b2cc09116bb38b16[/img]
Zagdima has attached the following image:
This post has been edited 3 times, last edit by "Zagdima" (Mar 6th 2020, 10:29pm)
eisbehr
Friday, March 6th 2020, 11:14pm
May I ask why you stack so many controllers on the same leds? What's the reason and what do you there?
peterzjt
Saturday, March 7th 2020, 5:00am
hello,Why my RGBFX sound bars mode doesn't work and the led doesn't respond to tasks,
Other sound modes are normal.
Looking forward to your reply. Thank you
The attachment contains the setup diagram.
peterzjt has attached the following files:
  • a1.jpg (94.09 kB - 3,243 times downloaded - Last download: Today, 10:00pm)
  • a2.jpg (71.38 kB - 2,831 times downloaded - Last download: Today, 3:45pm)
  • a4.jpg (92.61 kB - 3,092 times downloaded - Last download: Today, 3:52pm)
Zagdima
Saturday, March 7th 2020, 8:36pm
I'm not using all this controllers. Its just example how many controllers you can have. And for me its not enought). :rolleyes:
paskowitz
Sunday, March 8th 2020, 11:07pm
Just want to double check, presently there is no way to back up fan curves/rgb settings if you have an Octo/Quadro/Farbwerk 360? Is there a file in windows (program data or some similar folder) we can back up? Seems pretty strange you can back up an overview page and nothing else.
eisbehr
Sunday, March 8th 2020, 11:16pm
No, sadly not. :S AC says it's not worth to implement it, because it's too complicated. So they stick with dropping all settings, as this happen not so often, they pointed out in the german forum.
But you are not the only one who thinks this is "strange". ;)
sultan.of.swing
Wednesday, March 11th 2020, 2:46am
Having something on my system that has changed from X12 to X13.
I run 2 monitors and when I reboot my system and Aquasuite starts I have it set to load my main overview page.
In X12 this worked normal but in X13 it is opening the main page but at the same time it is putting it in desktop mode.
Not really a fan of that behavior and wondered if there is some new setting somewhere to change this? I don't see anything.
Wednesday, March 11th 2020, 4:41am
You mean it is opening in the Desktop editing mode in the aquasuite?
sultan.of.swing
Wednesday, March 11th 2020, 5:21am
No it is opening it in the mode where it pops out your page from aquasuite instead of it having the page in aquasuite itself.
Like this
sultan.of.swing has attached the following image:
Wednesday, March 11th 2020, 6:07am
Apologies, but I am not certain what having the page "IN" aquasuite means.
Let me try two suggestions that hopefully may help.
Assuming you want the display page to open on the desktop when you start aquasuite, make sure the "Load page automatically" option is selected on the Display page's configuration panel.
You may also want to set aquasuite to minimize at startup.
But if what you want is the Display page editing mode to not look like the Desktop (you picture), then deselect the page icon that is orange and make it white for another editing mode.
Sorry if I am not getting your issue.
sultan.of.swing
Wednesday, March 11th 2020, 6:29am
[attach]7280[/attach]
You can have the page in the aquasuite software or on the desktop if you click the little orange computer symbol.
The problem is when aquasuite starts up with the X13 version it starts up in "desktop" mode.
Not sure why it's hard to explain but it's not supposed to do this.
X12 opened like the first picture.
X13 opens like the second picture requiring me to have to take it out of "desktop" mode
sultan.of.swing has attached the following images:
This post has been edited 1 times, last edit by "sultan.of.swing" (Mar 11th 2020, 6:30am)
Wednesday, March 11th 2020, 2:37pm
For me, the aquasuite saves the "Desktop" mode status on exiting aquasuite.
If the Monitor icon is selected (orange) on exiting aquasuite, then that is the state on restart.
Conversely, if the Monitor icon is deselected (white) on exiting aquasuite, then that is the state on restart.
