Sie sind nicht angemeldet.
va3sd
But I can not use only one monitoring: AquaSuite does not have many data which could be monitored by Hwinfo, if I turned off AquaSuite monitoring and something happened with hwinfo (removed, stopped, freezed etc.)- all values in Aquasuite will be = 100.This is no aquasuite bug. Whenever you are using more than one software to monitoring your system you can have side effects with this 2 monitoring instances.Please tell me how can I create ticket or ask developers look into issue with sensors New: aquasuite X
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »va3sd« (17. Januar 2022, 16:55)
What Martin (author if HWINFO) suspects is that Aquacomputer is not using a global named mutex when polling this particular sensor. Using the mutex ensures that there are no polling collisions when multiple programs are polling the same sensor. HWINFO, AIDA64 and SIV all use mutexes to poll system sensors which is why these programs can be run simultaneously. Corsair ICue is an example of a program that does not use global named mutexes which is why iCue cannot coexist with HWINFO, SIV, or AIDA64. I am not a programmer, just restating what Martin said he thought was causing the issue. It seems that AQS does use mutexes or some other polling interlock to avoid polling collisions for other sensors, but not this one, so OP is seeing polling collisions. In the HWINFO thread that you posted a link to Martin says, "I can't tell this exactly as I have no insight into their code. There are several places and different methods to be used for proper synchronization, I assume they just forgot to implement it for accessing the NCT668x eSIO." Hopefully this will help to clarify what Martin thinks the problem is.For me it is 100% bug. You do not leave any options to setup default values if there are no data from external monitoring tool, such as hwinfo.
sebastian, Martin (HWiNFO Author) mentioned that Aquasuite developers can contact him if you are going to implement it.https://www.hwinfo.com/forum/threads/wrong-min-and-max-values-on-msi-z490-tomahawk.7806/post-33702
Has it been working for years or have there been polling collisions that no one noticed until va3sd noticed bad data values? You said further up that having 2 programs polling the same sensor can cause "side effects". This is only true if one or both of those programs is not using a global mutex to synchronize the polling requests. HWINFO author Martin has confirmed on his forum that the NCT668x eSIO requires a global mutex to synchronize access to the eSIO with other programs polling the same sensor. Can you please confirm that when you say you do it the correct way that this means you are using a global mutex, because this is the correct way. Martin probably knows more about how to properly poll sensors that just about anyone, so I tend to believe what he says, and the issue va3sd is having appears to be caused by a sensor polling collision. With all due respect, saying oh you can't do that or there may be "side effects" and it's been that way for years is not addressing the problem.We do this in the correct way. This is working since years without any issues.What Martin (author if HWINFO) suspects is that Aquacomputer is not using a global named mutex when polling this particular sensor
The aquasuite has a synconized access with hwinfo. The direct hw monitoring is a complete different thing. When you have issues with the Monitoring use only ONE Monitoring software. You can disable the aquasuite Monitoring or dont use hwinfo.This is only true if one or both of those programs is not using a global mutex to synchronize the polling requests.
va3sd
Let`s imagine: when I use only one monitoring and it is HWINFO if something happened with HWINFO (stopped, did not start or etc) all values which I use in Outputs = 100 it is default status what you guys implemented in your software!The aquasuite has a synconized access with hwinfo. The direct hw monitoring is a complete different thing. When you have issues with the Monitoring use only ONE Monitoring software. You can disable the aquasuite Monitoring or dont use hwinfo.This is only true if one or both of those programs is not using a global mutex to synchronize the polling requests.
I don't think that he confirmed this. He said he thinks that AQS is not using a global mutex to synchronize polling of this particular sensor. Sebastian said they do synchronize polling with HWINFO so maybe something else is causing the issue that va3sd has noticed.
AquaSuite has issue with getting monitoring sensors, HWINFO author confirms it,
va3sd
I do not like this tuning, it is workaround, I suppose it should work out of the box without any action from my side.I don't think that he confirmed this. He said he thinks that AQS is not using a global mutex to synchronize polling of this particular sensor. Sebastian said they do synchronize polling with HWINFO so maybe something else is causing the issue that va3sd has noticed.
va3sd - If you can monitor this sensor in AQS directly, but want HWINFO running for other reasons, you can disable monitoring of this particular sensor in HWINFO. If it's not polling the sensor, there can't be a collision. In HWINFO you select the sensor then press the Delete key. Have you tried that?
Well it's up to you. Sebastian said they do synchronize polling with HWINFO though he never said specifically that they are using a global mutex to do it. So maybe they are or maybe they are using some other method. Whatever they are doing, if the issues you are seeing are the result of polling collisions, disabling polling of that sensor in HWINFO should fix it. Aquasuite is a great program but its not perfect. My setup is relatively simple and I have encountered several bugs. Some I was able to convince them that it was actually a bug and they fixed it. Others seem to come and go and I just deal with them.I do not like this tuning, it is workaround, I suppose it should work out of the box without any action from my side.
exactly, I would need a fifth profile .. not essential, but usefulNot sure what you mean. The Octo already has profiles. Do you mean more profiles?Hi, would it be possible to add the possibility of creating other profiles also for the Octo?
Since X.45 you can have more than 4 Global Profiles but the Octo itself is still limited to 4 profiles. I don't know if its possible to add more Octo profiles. It may not be possible due to hardware limitations of the Octo. Someone from Aquacomputer would have to comment on this. I would also like to have more than 4 Octo profiles so will keep an eye on this thread.exactly, I would need a fifth profile .. not essential, but usefulNot sure what you mean. The Octo already has profiles. Do you mean more profiles?Hi, would it be possible to add the possibility of creating other profiles also for the Octo?
Remayz
Just remember that the 2 Farbwerks360's will not run in sync. I found that out the hard way when I installed a second one. Whether this is a problem depends on what RGB effects you are doing. I had to rethink my Farbwerk360 RGBpx port assignments to get everything I wanted to sync on the same Farbwerk360.i am bumping on that limit, but the real problem is RGB for me. Since the Octo also controls two channels, i'd need more presets, but if it was only controlling fans i wouldn't need more fan curves.
So, going to get a second Fw360 to get rid of RGB control on the octo (and get effect stacking support thanks to the farbwerk).
each preset will be tied to a fan curve on the octo, but pretty much always the same one.. on all profiles.
That's one way to get rid of the Octo limitation, but it costs a few €
Remayz
it's OK. I either run a flame effect (out of sync looks better) or RGB puke for when i feel depressedJust remember that the 2 Farbwerks360's will not run in sync. I found that out the hard way when I installed a second one. Whether this is a problem depends on what RGB effects you are doing. I had to rethink my Farbwerk360 RGBpx port assignments to get everything I wanted to sync on the same Farbwerk360.i am bumping on that limit, but the real problem is RGB for me. Since the Octo also controls two channels, i'd need more presets, but if it was only controlling fans i wouldn't need more fan curves.
sooo, no worries ! Freitag, 4. Februar 2022, 04:20
