• 30.11.2026, 21:54
shrubdog
Wednesday, August 25th 2021, 5:07pm
Okay, here are a few screenshots from my settings. Running version .43 now. I have attached them as I don't have image hosting handy.
Fans 1-6 are all Cooler Master case fans, fan group 7 is a set of EK fans that push air over my EK AIO 360 radiator. For some reason they are always spinning up to higher RPMs, even when I put them on the same curve.
shrubdog has attached the following images:
This post has been edited 1 times, last edit by "shrubdog" (Aug 25th 2021, 5:09pm)
CodeZ1LLa
Wednesday, August 25th 2021, 7:05pm
Changelog
[color=]aquasuite X.43[/color] (25-AUG-2021)
  • New: In the Playground all modules can be activated and deactivated individually
  • New: Maintenance mode for the Playground
  • Update: Hardware monitoring
  • Change: Notifications within the aquasuite
  • Change: Firmware update process
  • Change: Aqua Computer service log
  • Bugfix: Playground automatic profile switching
  • Bugfix: Hardware monitoring settings
  • Bugfix: RGB input
Thanks for update! If possible, please, add RAM temperature reading.
CodeZ1LLa
Wednesday, August 25th 2021, 7:18pm
I wondering why my Aquasuite looks completely different... Anyway, make sure that the fans are in the correct mode: [url]https://i.imgur.com/bXrlDWP.png[/url]
Alex132
Wednesday, August 25th 2021, 7:53pm
Out of interest, do you guys think HWiNFO64 version 7.x+ would ever be supported? I know their devs changed something with how other programs can grab monitoring info and it's messed up a few programs.
Remayz
Wednesday, August 25th 2021, 8:42pm
it never ceased to be supported afaik. I'm using it right now instead of AC service :)
you have to enable shared memory support in HWinfo to have other programs access it. the setting reverts to disabled after 12 hours. Only the licensed version has no time limit.
Remayz
Wednesday, August 25th 2021, 8:54pm
the EK fans have a zero RPM mode, they should stop below 25% PWM. I don't know how the AIO manages that, or if your fans are connected directly to the Octo, but that could be a clue. your fan curve goes way below that.
try going to "power preset" for speed control and increase slowly the PWM %, and see if at 25 - 26% they suddenly drop to their slowest speed, and then respond normally from there.
If that's the case, you'll have to make a second fan curve for the AIO
Wednesday, August 25th 2021, 10:26pm
What does the "New: Maintenance mode for the Playground" do?
shrubdog
Thursday, August 26th 2021, 12:33am
My EK fans respond all the way down to 1%, so the Zero RPM mode isn't activated on these.
Also, the interface for Fan Setup in my .43 version of Aquasuite doesn't have anything to select fan type, so I'm assuming that the OCTO is auto-detecting. (They're all PWM anyway.)
Of course, the system has been behaving pretty well today since I posted-- it might have been chewing on a Windows update.
Remayz
Thursday, August 26th 2021, 7:04am
the Octo is PWM only, it doesn't do control on 3 pin DC fans, so that option is out :)
Thursday, August 26th 2021, 7:39am
This disables all Playground modules. This prevent during Maintenence/Update a shutdown or other unwanted notifications.
Thursday, August 26th 2021, 1:35pm
We should enable Maintenance Mode prior to updating, or is that done automatically?
Thursday, August 26th 2021, 2:13pm
After a aquasuite update this is automatically on and when no firmware update is required it is automaticalliy off.
This is useful when you cange some settings and have shutdown actions in your playground.
AE5probigNGslave
Thursday, August 26th 2021, 8:04pm
Changelog
aquasuite X.43 (25-AUG-2021)
  • Bugfix: RGB input
LEAKSHIELD Firmware 1010:
VISION Firmware 1017:
VISION RGBpx Firmware 1008:
Dear ac,
I have problem with flow sensor . Value does not show on Vision. This problem was in the past too after another update. See pictures below.
Thak you.
AE5probigNGslave has attached the following images:
Thursday, August 26th 2021, 8:16pm
I got myself into trouble when I set up a command to shut down windows if an Octo fan port RPM goes below a trigger value. My computer was shutting down as soon as AQS started. Did a System Restore to get out of it. I learned later that I could have booted into Safe Mode and edited the XML file. This feature should protect against dummies like me doing dumb things like this. Thanks for adding this.
Flop Ysh
Thursday, August 26th 2021, 9:35pm
[edit]the update disabled all hardware monitoring
This post has been edited 2 times, last edit by "Flop Ysh" (Aug 26th 2021, 9:39pm)
shrubdog
Thursday, August 26th 2021, 10:01pm
I have an intermittent problem where sometimes my OCTO and my MB have a fight over the USB, and the OCTO won't spin up the fans, and Aquasuite won't recognize it. Windows goes through an unending connect/disconnect loop until I reboot or shut down. (That usually fixes it.)
It's not common by any means, and I've never been able to figure out the root cause of it. I think it *may* be my Xbox wireless controller dongle, but that's just speculation. It could also be a random bug.
Anyway, I just had the connect/disconnect loop happen today with the OCTO, and on reboot, all of my fan control settings were wiped in Aquasuite. (ver .43) Is that a known bug?
woizzz
Friday, August 27th 2021, 8:04pm
Same issue as AE5probigNGslave posted above.
After update to X.43, sensor data from MPS connected via USB doesn't shows in software sensors.
woizzz has attached the following images:
Monday, August 30th 2021, 9:56am
the bugfix release is online.
woizzz
Monday, August 30th 2021, 11:50am
Works great now! Thanks
AE5probigNGslave
Monday, August 30th 2021, 9:12pm
Working...
Extraordinary support as always...
Thank you !!!
