• 06.10.2026, 05:43
Dundys
Donnerstag, 23. Februar 2023, 01:46
What is with aquasuite X66 stuck as (Insider) for weeks now
AQS X.60 had the big update to .NET 7.0 runtime environment. X.60 and every version since has been an Insider Edition. The Bug Report Thread they started with X.65 (since pulled) is still active on the German Forum. Maybe they are still tweaking the migration to .NET 7.0. It is unusual because the 10 releases prior to X.60 were all NOT Insider Editions.
Thanks for the info, didn't think abut that :thumbup:
Methodical
Sonntag, 5. März 2023, 21:13
I created multiple backups in Aquaero 6. Is it possible to delete the backups that are no longer needed? If so, how do delete them?
Thanks...
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Methodical« (5. März 2023, 21:14)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Jacob
Montag, 6. März 2023, 11:42
Thanks...
C:\ProgramData\aquasuite-deta\
C:\Users\User_name\OneDrive\documents\aquasuite\profiles
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Jacob« (6. März 2023, 11:43)
Methodical
Dienstag, 7. März 2023, 00:11
Cool. Thanks^^
Hopper64
Donnerstag, 9. März 2023, 04:31
Just updated to VX.67 and noticed an updated version of .net runtime 7.0.3. I had V7.0.0 installed and simply installed over the top without uninstalling the prior version. It appears to be working correctly. Do you have to uninstall .net V7.0.0 before updating to V7.0.3? Thanks.
Donnerstag, 9. März 2023, 07:18
Old versions can be uninstalled.
Hopper64
Donnerstag, 9. März 2023, 12:44
I installed over the top without uninstalling the prior version, but it looks like the installer simply overwrote the prior version. Only 7.0.3 is visible in add/remove programs in windows. Seems to be functioning correctly.
Methodical
Donnerstag, 9. März 2023, 15:42
According to the Change Log this firmware updates calibration for all flow sensors, did you notice any change to flow sensor data?
Donnerstag, 9. März 2023, 16:08
High Flow Next w/firmware 1016
X66 flow rate: 2.5 l/m
X67 flow rate: 2.5 l/m
Donnerstag, 9. März 2023, 16:30
You cant setup calibration values for High Flow Next Sensors.
This is for all sensors that are directly connected to a device like the octo, quadro ....
The new calibration values are selected when you select the type of flow sensor in the Sensor tab of each device.
Remayz
Donnerstag, 9. März 2023, 17:11
damn, i just gained almost 20L/h. free upgrades lol
the DP Ultra / water drop down list, i wonder what to chose when we use a 3rd party coolant.
Methodical
Donnerstag, 9. März 2023, 23:05
[attach]10153[/attach]
That is good to know. I have 1 flow sensor connected via Octo. Will I get this option if I have the Octo connected to the AQ via an Aquabus connection.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Methodical« (9. März 2023, 23:08)
Methodical
Donnerstag, 9. März 2023, 23:09
Do you get any other options in the drop down list?
Hopper64
Freitag, 10. März 2023, 01:18
No. Flow data appears to be the same to me. Thanks.
Remayz
Freitag, 10. März 2023, 04:00
Nop, just those two. I don't suspect they'd go to the trouble to fine tune every coolant on the market. I don't even know what that does.. if it slightly changes flow depending on said fluid viscosity or whatever :p
Dundys
Freitag, 10. März 2023, 18:10
Since earlier releases of (X52 or X55 I don't quite remember) I have been saving my profiles settings and importing every time new version is released. Is there any negative effect of doing that, especially I'm curious with the latest X67 that uses runtime 7 and if its better to set curves and create everything from scratch again, although, everything seem to work as it should after importing my old settings.
Thanks
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dundys« (10. März 2023, 18:12)
Remayz
Freitag, 10. März 2023, 19:10
i personaly just backup the settings but never import them. I always just install, keeping current settings, and i never lost anything.
Dundys
Freitag, 10. März 2023, 19:30
Thanks
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dundys« (10. März 2023, 19:34)
henson0115
Samstag, 11. März 2023, 15:47
what's the possibility of getting more control over rgbpx audio effects? like fade, randomizing colours for sound flash, filtering. the controls are fairly basic right now, are they are plans to improve it?
Remayz
Samstag, 11. März 2023, 18:30
I don't use the audio ones, but new effects, or just anything new on the lighting side would be cool :)
