• 30.11.2026, 22:03
SpinCykle
Tuesday, June 23rd 2020, 6:19pm
Same issue... Updated to X21 and can't start Aqua Computer Service. Is there a log file somewhere to see whats prevent the Aqua Computer Service from starting? 100% fan speed ... Mmmmmmmmmmm
Tuesday, June 23rd 2020, 8:08pm
stop the service and try to delete the file:
Source code
1
C:\ProgramData\aquasuite-data\Settings_VirtualSoftwareSensor.xml
otherwise make a clean install with the aquasuite setup
SpinCykle
Tuesday, June 23rd 2020, 11:15pm
Source code
1
How can I recover all my virtual sensors that were in the playground? This does not exactly "solve" the issue.
Wednesday, June 24th 2020, 7:58am
send all *.xml files (zipped) from the data folder to info@aqua-computer.de
We can try to reproduce the error. Currently we cant reproduce this issue.
Tasky
Saturday, June 27th 2020, 4:03pm
Where are the RGBpx fireworks, balls and highlight effects from X.18?
I've found the rotations and all the others... have some been removed?
Dundys
Saturday, June 27th 2020, 5:42pm
Every new release there is something new acting up :thumbdown: . X21 half the time wont restart with Admins rights via program itself, unless you right click and run that way, for now I went back to X17.
This post has been edited 1 times, last edit by "Dundys" (Jun 27th 2020, 5:43pm)
Bartdude
Monday, June 29th 2020, 7:03am
Ii noticed on initial install of X21 that the hardware info under Aquasuite was again working for CPU & GPU temps. Came back the next day and they have gone to 50% static again! I can pull them in from HWINFO but why has Aquasuite suddenly stopped reporting the correct values?
k2viper
Monday, June 29th 2020, 9:13am
What helped me: In taskschd.msc find an aquasuite startup task, go to its settings and check the checkbox "Run with highest privileges".
Monday, June 29th 2020, 11:07am
Maybe try to raise the start delay time. The aquasuite might not start (crashes in the background) because some relevant system parts are not loaded yet.
johnnybra
Monday, June 29th 2020, 1:22pm
Hi all:
After today update (X.22), It seems that Aquasuite service is using tons of resources
Any suggestion?
This post has been edited 1 times, last edit by "johnnybra" (Jun 29th 2020, 1:23pm)
Monday, June 29th 2020, 1:48pm
Try to power off your PC (no hybernation) and start again.
Dundys
Monday, June 29th 2020, 2:13pm
Thanks but didn't help. In fact now, It wont start at all via program, until you right click and run as admin. One thing fixed, another broken :thumbdown:
johnnybra
Monday, June 29th 2020, 2:19pm
I restart my PC several times because It also doesn't start with administrator rights (but this happened with previous versión too)
Dundys
Monday, June 29th 2020, 2:31pm
I got to quit updating aquasuite. X17 seem to work with least issues :whistling:
k2viper
Monday, June 29th 2020, 4:18pm
Bugfix: Comment element in the playground crashes the background service
Nice one.
Background service crashed after restart was my X.21 update trouble.
I spent a few hours fresh reinstalling aquasuite X.21 and manually re-creating all my Playground sensors, because one of them had text comment element?!
Does Aquacomputer test their releases before rolling out?
This post has been edited 2 times, last edit by "k2viper" (Jun 29th 2020, 4:22pm)
johnnybra
Monday, June 29th 2020, 5:15pm
Fixed after a completly new fresh installation, but still no administrative privileges when Aquasuite starts with Windows.
Hi all:
Any suggestion?
Dundys
Monday, June 29th 2020, 5:27pm
Yap, X22 won’t restart via aquasute with amins rights, it’s broken.
This post has been edited 1 times, last edit by "Dundys" (Jun 29th 2020, 5:28pm)
Monday, June 29th 2020, 7:19pm
the autostart function is working.
Dundys
Monday, June 29th 2020, 8:09pm
I'm not quite sure what you referring to, but I'm talking about is while aquasuite is running and if you go to settings and try to restart with admins rights, 9 of 10 times won't restart. X.17 as far is that part goes, when chosen to run with amins rights, works without glitch, every single time, so that is a bug.
This post has been edited 1 times, last edit by "Dundys" (Jun 29th 2020, 9:05pm)
Monday, June 29th 2020, 9:41pm
the aquasuite dont need any admin rights for 99% of the settings. only a few swttings require admin rights.
