• 08.10.2026, 06:52
Monday, August 17th 2020, 1:08pm
try to install the lastest vcredist package from microsoft.
Have you installed the aquasuite into the default path:
Quoted
C:\Program Files\aquasuite
and all windows Updates installed?
rad
Monday, August 17th 2020, 1:28pm
Thanks, yes I've installed into default folder. And .net 4.8 runtime package from the installer link to Microsoft site
Actually after installing the latest graphics drivers this fixed the issue. Don't know whether it was the graphics driver itself or the redist package installed along with the nvidia package.
This post has been edited 2 times, last edit by "rad" (Aug 17th 2020, 2:06pm)
henson0115
Tuesday, August 25th 2020, 11:10am
anyone else notice that the until you restart the service, nothing happens with the fans after x26, if i restart the service it works and its not all the time, appears random.
Tuesday, August 25th 2020, 12:43pm
Have you tried increasing the 'Start delay' in the aquasuite settings tab? start_delay.jpg
Hopper64
Thursday, September 10th 2020, 12:30am
Noticed the new X.27 version. I guess this is available for download since it’s not an insider. There is no date or version designation for the download. Does anyone know if this is correct?
henson0115
Monday, September 14th 2020, 2:32pm
Have you tried increasing the 'Start delay' in the aquasuite settings tab? [attach]7688[/attach]
no will try this thanks!
actually tried x27 first, this makes it even worse, if i enable any of the hardware monitoring (tick the hardware monitoring boxes), the fans get stuck at like 1300rpm, if i disable all fo the options, they work again. i am also using hwinfo and i think its a clash with this.
now gunna try adjusting the start up delay
This post has been edited 1 times, last edit by "henson0115" (Sep 14th 2020, 2:36pm)
Tuesday, September 15th 2020, 1:13am
I, and many, use HWiNFO and I have never had a conflict related to it.
Hopefully delaying the startup will improve your user experience.
henson0115
Tuesday, September 15th 2020, 5:28pm
ive changed the delay to 2 seconds and so far so good, if i see any other similar issues i will adjust to 3 and so on. the monitoring conflict has subsequently gone away. very odd but at least its working as intended now! thanks again for the assist :)
henson0115
Friday, September 25th 2020, 6:28pm
gets a bit odder, every now and again randomly, the service needs a reboot after start up, else the fans will ignore the curve. once rebooted (the service) it all works fine.
Winczlav
Wednesday, September 30th 2020, 9:43am
Can I control the RGB of my Asus Hero X motherboard ? And same for the Corsair Waterblock XC7 ?
Thanks.
Wednesday, September 30th 2020, 9:53am
You Can only control LEDs that connected with aqua computer devices.
Winczlav
Wednesday, September 30th 2020, 10:22am
Ok, so if I connect my XC7 and XG7 waterblock to a Quadro or Octo, it should work ?
That's also mean I can't control the RGB of my motherboard, correct ?
Thanks for your help.
Wednesday, September 30th 2020, 2:19pm
No, you can't. The motherboard LEDs cannot be controlled from the outside.
I can't say much about the water blocks, according to the manual they have a three pin connector, but it doesn't fit on a Quadro or Octo.
The RGBpx Splitty 4 offers the possibility to adapt Corsair LED fans, but it has a four-pin connector for the fan LEDs, so this will probably not work.
So I would assume that there is no possibility!
Translated with www.DeepL.com/Translator (free version)
k2viper
Wednesday, September 30th 2020, 3:57pm
Corsair XC7's RGB connector looks quite similar to those on Corsair RGB fans, and Corsair i-cue controller compatibility is claimed. So it should work with any Aquacomputer RGBpx controllers (in Quadro/Octo/D5NEXT/farbwerk360) through Splitty4. Although XC7 connector is 3-pin, meaning it does not have "data out" wired, so this block should only be connected as last device in any RGBpx LED chain.
Bauer
Monday, October 12th 2020, 2:08am
My temperature sensors randomly disappear forcing my pump and fans to 100%, is there a fix for this ?
k2viper
Wednesday, January 13th 2021, 8:42am
Bauer
If it is a software sensor (not a phy sensor connected to an aquacomputer device) then most likely, your aquacomputer device loses USB connection.
Make sure that your Windows power plan do not allow to disable USB connections.
JustinThyme
OCTO DIED
Thursday, January 14th 2021, 5:23am
After Jan 13 OCTO is now dead in the water. Won’t work at all connected to USB or standalone. Worked perfect before update.
Thursday, January 14th 2021, 8:17am
Quoted
write a Mail to the Support.
The version X35 is online. All those who have updated to version X32..X34 should update to X35.
Asryan
Thursday, January 14th 2021, 8:42am
Annoying that we know have to unplug all fans from quadro for instance to update.. need to replug pump on motherboard and so...
altruistic
Thursday, January 14th 2021, 10:29am
This. All these updates in the last days were kinda annoying, but this just put the cherry on top :thumbdown:
