• 30.11.2026, 22:03
SpinCykle
mardi 23 juin 2020, 18:19
Same issue... Updated to X21 and can't start Aqua Computer Service. Is there a log file somewhere to see whats prevent the Aqua Computer Service from starting? 100% fan speed ... Mmmmmmmmmmm
mardi 23 juin 2020, 20:08
stop the service and try to delete the file:
Code source
1
C:\ProgramData\aquasuite-data\Settings_VirtualSoftwareSensor.xml
otherwise make a clean install with the aquasuite setup
SpinCykle
mardi 23 juin 2020, 23:15
Code source
1
How can I recover all my virtual sensors that were in the playground? This does not exactly "solve" the issue.
mercredi 24 juin 2020, 07:58
send all *.xml files (zipped) from the data folder to info@aqua-computer.de
We can try to reproduce the error. Currently we cant reproduce this issue.
Tasky
samedi 27 juin 2020, 16:03
Where are the RGBpx fireworks, balls and highlight effects from X.18?
I've found the rotations and all the others... have some been removed?
Dundys
samedi 27 juin 2020, 17:42
Every new release there is something new acting up :thumbdown: . X21 half the time wont restart with Admins rights via program itself, unless you right click and run that way, for now I went back to X17.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Dundys" (27 juin 2020, 17:43)
Bartdude
lundi 29 juin 2020, 07:03
Ii noticed on initial install of X21 that the hardware info under Aquasuite was again working for CPU & GPU temps. Came back the next day and they have gone to 50% static again! I can pull them in from HWINFO but why has Aquasuite suddenly stopped reporting the correct values?
k2viper
lundi 29 juin 2020, 09:13
What helped me: In taskschd.msc find an aquasuite startup task, go to its settings and check the checkbox "Run with highest privileges".
lundi 29 juin 2020, 11:07
Maybe try to raise the start delay time. The aquasuite might not start (crashes in the background) because some relevant system parts are not loaded yet.
johnnybra
lundi 29 juin 2020, 13:22
Hi all:
After today update (X.22), It seems that Aquasuite service is using tons of resources
Any suggestion?
Ce message a été modifié 1 fois. Dernière modification effectuée par "johnnybra" (29 juin 2020, 13:23)
lundi 29 juin 2020, 13:48
Try to power off your PC (no hybernation) and start again.
Dundys
lundi 29 juin 2020, 14:13
Thanks but didn't help. In fact now, It wont start at all via program, until you right click and run as admin. One thing fixed, another broken :thumbdown:
johnnybra
lundi 29 juin 2020, 14:19
I restart my PC several times because It also doesn't start with administrator rights (but this happened with previous versión too)
Dundys
lundi 29 juin 2020, 14:31
I got to quit updating aquasuite. X17 seem to work with least issues :whistling:
k2viper
lundi 29 juin 2020, 16:18
Bugfix: Comment element in the playground crashes the background service
Nice one.
Background service crashed after restart was my X.21 update trouble.
I spent a few hours fresh reinstalling aquasuite X.21 and manually re-creating all my Playground sensors, because one of them had text comment element?!
Does Aquacomputer test their releases before rolling out?
Ce message a été modifié 2 fois. Dernière modification effectuée par "k2viper" (29 juin 2020, 16:22)
johnnybra
lundi 29 juin 2020, 17:15
Fixed after a completly new fresh installation, but still no administrative privileges when Aquasuite starts with Windows.
Hi all:
Any suggestion?
Dundys
lundi 29 juin 2020, 17:27
Yap, X22 won’t restart via aquasute with amins rights, it’s broken.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Dundys" (29 juin 2020, 17:28)
lundi 29 juin 2020, 19:19
the autostart function is working.
Dundys
lundi 29 juin 2020, 20:09
I'm not quite sure what you referring to, but I'm talking about is while aquasuite is running and if you go to settings and try to restart with admins rights, 9 of 10 times won't restart. X.17 as far is that part goes, when chosen to run with amins rights, works without glitch, every single time, so that is a bug.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Dundys" (29 juin 2020, 21:05)
lundi 29 juin 2020, 21:41
the aquasuite dont need any admin rights for 99% of the settings. only a few swttings require admin rights.
Discussions similaires
