• 06.10.2026, 13:23
Vladimir M
Dienstag, 18. Mai 2021, 11:39
Hello. New version X.39 keeps crashing.
List your devices and a few details about your system and Software. Cloase ALL other software Afterburner, RTSS,.. maybe one of the last Microsoft updates is corrupt. Try to remove all *.page files in the folder:
C:\ProgramData\aquasuite-data
after installation before you start the aquasuite.
complete uninstall aquasuite
The C:\ProgramData\aquasuite-data folder was empty. delete the folder
install aquasuite
Still crashing every ~3 hours
Can you give me x.38 to check?
P.S.
It also happened to me once:
"the latest x39 version - aqua computer service causes high CPU usage after the reboot, talking 15-20% usage on a 3900x for the service alone, it looks like a bug to me."
Windows 10 last update
3900x
2080 Super
Asus X570-E
4 - G Skill F4-3600C16-16GTZNC
D5 NEXT, farbwerk 360, highflow NEXT
last GPU, Chipset... drivers
Not installed Afterburner, RTSS
Antivirus: KIS
Update:
I'm going to try:
"remove all *.page files in the folder after installation before start the aquasuite."
Dieser Beitrag wurde bereits 9 mal editiert, zuletzt von »Vladimir M« (18. Mai 2021, 14:14)
Vladimir M
Mittwoch, 19. Mai 2021, 10:03
Now I don't have any *.page files in
Everything is working. No crashing.
Update:
Still crashing!
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Vladimir M« (19. Mai 2021, 11:57)
Vladimir M
Freitag, 21. Mai 2021, 07:07
I have windows backup with x.38 - everything is working. No crashing
If update to x.39 - crashing every ~3 hours
selvakumar1989
RE: New: aquasuite X
Sonntag, 23. Mai 2021, 05:51
Hi we need detailed manual in English
Thunder-74
Montag, 31. Mai 2021, 18:06
hi,
I report an anomaly on the rev. x39 .. when I change the profile, the start boost power of the OCTO resets back to 100%
Cpu i9 13900k Liquid EK Velocity2 - Mobo Z690 Aorus Master - Ram 48Gb DDR5 - Gpu 5090 Gigabyte Gaming OC Liquid WB Alphacool - M.2 NVMe 5 x 11 Tb SSD 3 x 7 Tb - Liquid Rad 360/60 - 2x 240/30 - 2x D5 / Aquaero 6 XT / 2x Octo / MPS 400 / Ampinel - Audio Sound Blaster X3 - 5.1 Edifier S550 - PSU TT GF3 1200W - Monitor LG 45GX950A
Jimmeh
Dienstag, 1. Juni 2021, 18:05
Just to add - I am also having the crashing issue since v39. I have also wiped and started from scratch my Windows 10 installation, and have not carried forward my overview pages.
Dragonix
Mittwoch, 9. Juni 2021, 08:27
Hello. Same here. Version X.39 keeps closing every 3-12 hours. I'm using Windows 10 version 10.0.19042 Build 19042.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dragonix« (9. Juni 2021, 08:29)
Dundys
Donnerstag, 10. Juni 2021, 01:36
Ohh..that's what is happening :!: I see this behaviour as well, all of the sudden aquasuite is closed and it does happens randomly every several hours. When I first so aquasuite closed I thought I just closed it by accident, but obviously that's not the case :D
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Dundys« (10. Juni 2021, 01:38)
d0mmie
Freitag, 11. Juni 2021, 10:24
I've been having an issue with Aquasuite X.39 over the last couple of weeks that once my PC wakes up from hibernation, some times (most of the times) some of my soft sensors like CPU, GPU, PCH, etc no longer work in Aquasuite and just lists the values as "--". Only way to fix it, is to restart the Background Service for the data to be populated in Aquasuite again.
Dundys
Sonntag, 13. Juni 2021, 01:02
Its been days now and so far all working good with X39, no issues...mysterious :)
Remayz
Sonntag, 13. Juni 2021, 05:23
I discovered a random issue after getting a Farbwerk nano to do some ambilight on my desk. maybe it's a bug, maybe it's not..
When creating an ambilight preset, Aquasuite insists that both video analyzer AND audio analyzer be active at the same time, otherwise, the ambilight settings are not shown.
So i have to activate the audio analyzer.. set my lighting, then disable the audio analyzer because i don't need it for ambilight.
I understand the audio analyzer barely taxes the CPU and could be left on but, is that behaviour normal?
Dominus
Mittwoch, 16. Juni 2021, 04:28
Hello guys, how to enable Octo and Quadro in HiveOS (Ubuntu)? Please very need help.
mditsch
Mittwoch, 16. Juni 2021, 05:52
When the devices are configured, they will work without a running SW. For using Aquasuite to configure the devices you have to use a windows VM. No Linux SW is available for Aquacomputer devices.
Dominus
Donnerstag, 17. Juni 2021, 08:33
So in theory I can setup rules of gpu cooling in windows after that reboot in linux/ububtu/hive and it will work?
Until power off?
Donnerstag, 17. Juni 2021, 09:12
All values that you want to use for control must come from sensors that are directly connected to the OCTO/QUADRO.
There is no possibility to connect OCTO and QUADRO to exchange values under Linux.
So it is also not possible to use read values from the mainboard or the GPU.
In addition, all settings that you make with the Aquasuite are stored locally in the OCTO/QUADRO and are therefore completely autonomous.
Translated with www.DeepL.com/Translator (free version)
Dominus
Donnerstag, 17. Juni 2021, 11:28
Understand. There is no plan to make support of linux for octo/quadro?
Donnerstag, 17. Juni 2021, 11:45
No, nothing will happen because the market is too small and the effort too great.
phuzz
Donnerstag, 17. Juni 2021, 17:46
Also having the crashing problem on X.39, which has revealed another problem.
Although all the checkboxes are checked for event logging (aquasuite, Aqua Computer Service, and Notifications), it doesn't seem to be logging. There's no .log files in C:\ProgramData\aquasuite-data.
Because of that all I can attach is the Windows event logs:
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
Application: aquasuite.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArgumentOutOfRangeException
   at System.ThrowHelper.ThrowArgumentOutOfRangeException(System.ExceptionArgument, System.ExceptionResource)
   at AquaComputer.DeviceAccess.HistoryData.GetStatisticData(System.TimeSpan)
   at AquaComputer.Overview.DataControl.DataItem.O1d8OP4MQTT8bELJhJnE(System.Object, System.TimeSpan)
   at AquaComputer.Overview.DataControl.DataItem.QmVCl3kaHi()
   at AquaComputer.Overview.DataControl.DataItem.HHICLUxLST()
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Application.RunDispatcher(System.Object)
   at System.Windows.Application.RunInternal(System.Windows.Window)
   at AquaComputer.Aquasuite.App.Main()
softlion
what do you think of my virtual sensor ?
Samstag, 19. Juni 2021, 09:13
Hello,
I'm enjoying it since 5 years but you may have some remarks to make it better ?
And the dependent one (air / water temperature difference)
The controllers
Result
Thanks ! ?(
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »softlion« (19. Juni 2021, 09:15)
Remayz
Samstag, 19. Juni 2021, 15:38
Well.. forget CPU and GPU temp :) with watercooling it's pretty much useless. your PC seems to run a bit hot, the pump speed moves up and down without any effect on temperature.
Only fan speed affects water temp. Only water temp affects CPU/GPU temp.
You only need enough pump speed to have sufficient flow for cooling to be efficient. Depending on your loop, a fixed 50 or 60% can be more than enough.
Your computer seems to run hot too, fan speed is so low the water temp keeps climbing, so you get close to 40° case temp, thats why the NVME and ram are hot as they are. It's still technically fine though.
Maybe make a fan sloped curve instead of stepped? and higher PWM% ? your fans seem to be low RPM ones so it would help running them a bit faster.
If you keep water temp in check, CPU, GPU and VRAM temps will be in check. That simplifies your virtual sensors since you don't need to worry about these 3 temps at all.
